Drivetrain Tech General discussion of drivetrain for the Ford Ranger.
clutch housing gasket information
Old 07-22-2015
fordruggedman's Avatar
Hello ya'll!
this has probably been posted somewhere in drivetrain tech forum somewhere and I don't have time to search it.
I'm in process of replacing my clutch slave cylinder or throwout bearing assembly either way you wanna call it ... i had someone installed for me and didn't bother to torque down on the bolt and it causes not wanna shift gears properly on me ... grrr
Is there a bellhousing or clutch cover gasket available to get? and as well there's an fly wheel gasket seal behind it ... I need those numbers .... I have a HELL of time finding it.
here's an example pic of what I need:
I have 5 speed manual transmission with V-6 4.0L
Thank you for your help!
Old 07-22-2015
IN2 FX4's Avatar
I have never heard of a bell housing or flywheel gasket. There is no need for them as far as I know. I have seen a shim used on the bell housing but never a gasket. A flywheel should be in direct contact with the crankshaft. Any gasket material between them could cause a wobble in the flywheel, which would be a very bad thing.
Old 07-22-2015
RonD's Avatar
Received 2,820 Likes on 2,586 Posts
There is the Main seal on the crankshaft which is behind the flywheel, the 4.0l is not known for leaking "rear main seal" but many replace this seal because it is under $10 and a pain to change if it does ever leak, i.e. you have to pull out the transmission again.
You do have to be careful changing it, if you scratch the crank shaft it WILL leak when you start engine
but as IN2 said there are no block to bell housing gaskets on any Ranger
Old 07-22-2015
ooh okay thank you for your inputs guys ... another question ... before removed the drive shaft from the transfer case ... I drain the fluids. it was filled with gear oil. I seen places like autozone and O' Reilly where they have specification pages telling you to use automatic transmission fluid ... is it wise to stay with gear oil to ensure preventing damage to gears?
I have to check my manual book to see what type of either automatic transmission or grade gear oil i need to use. I'll look to be sure or I'll be sorry and not a happy camper!
Old 07-22-2015
RonD's Avatar
You list a 2WD in your profile, so no transfer case?
And no reason to drain fluids to replace clutch parts in any case.
You can drain and refill if you want, just not required.
Yes, the M5OD-R1 manual transmission uses ATF
Pre-'98 should use MERCON, but Ford no longer has it made so equivalent is Dex/Merc which is still available.
'98 and up uses MERCON V
Many have used Royal Purple Synchromax in any year with good results, it is a synthetic oil product
Uses about 2.5quarts if fully drained
Transfer case info here if needed: Transfer Case Fluid Change
Old 07-22-2015
oops I remmy not having transfer case with my truck .... transfer case is like a 4 x 4 right? if so I don't have that feature. My bad!
Well I had to drain the gear oil from transmission to remove the drive shaft from trans for easy removal since I'm planned on replacing the clutch slave assembly this weekend.
What kind of grade gear oil recommend using Royal Purple Synchromax? I may be doing some heavy haulin!
Thank you
Old 07-22-2015
here's my answer too this question ...
royal-purple
Thank you again for ya'll help! :) unforunetly my truck isn't covered under warranty so I'll stick with performance upgrade recommendation: Synachromax manual transmission like u suggested :)
Old 07-24-2015
well I have another question too ask ...
How do I disconnect this? Haynes manual book doesn't tell ya squat
cuz' i have to put in new clutch tube line that runs from clutch booster into throwout bearing ... any suggestion are welcome :)
and
Old 07-24-2015
RonD's Avatar
Google: ford ranger clutch line disconnect
Couple of videos to watch
talkforparts
0
07-20-2010 01:41 PM
Funeral98
Suspension Tech
23
06-27-2006 02:36 PM
Sad_Savant
Ranger-Forums Office
6
04-18-2005 06:54 PM
n3elz
4.0L OHV & SOHC V6 Tech
70
02-06-2005 12:33 AM
Quick Reply: clutch housing gasket information
