Wheel size help.
Old 12-23-2005
jdpartsman99's Avatar
Wheel size help.
I plan on getting a set of Micky Thopmson Classic II's and some more aggressive tires for the summer months and running the stock Alcoas and BFG's in the winter.
What size 15x7 or 15x8 should I get? I plan or running 31x10.5x15 tires. Also, what is the bolt pattern on our trucks? Thanks.
02 Ranger FX4 L2
Old 12-23-2005
The bolt circle is 4 1/2". Level II's came from the factory with 15x7, +12mm offset, 4.5" backspacing. If you stay close to those numbers, you should be able to avoid any rubbing issues.
Old 12-23-2005
BILLZFX4's Avatar
I am ALMOST sure that Mickey Thompson does not make 15x7, so you will have to go 15x8.
Old 12-24-2005
rangererv's Avatar
i'd go with 15x8's either way.
a 31x10.5 is about the biggest you want to put on a 15x7 anyways.
Old 12-27-2005
The MT's I am looking at are part #358421. 5 bolt on 4.5 bolt circle, 3 and 5/16 backspacing, no clue on the offset.
Will this be OK?
02 Ranger FX4 L2
Old 12-27-2005
Will this be OK?
02 Ranger FX4 L2
8" width and 3 5/16" BS gives an offset of about -30mm. Stock is +12mm. These wheels would push your tires out about 12+30 = 42mm or roughly 1 3/4". You may possibly get minor rubbing on the mudflaps or inner fenders when the steering is turned to the stops.
Old 12-27-2005
rwenzing,
Man....your smart with this stuff. I really would like to keep my tires inside the fenders. I wash it enough...I don't need the more crap getting thrown all over the place. I think I will keep looking for awhile.
02 Ranger FX4 L2
Old 12-27-2005
Ok...one more try. American Racing wheels. 15x8, 5-bolt 4.5 bolt circle, 19mm offset, back spacing of 3.75 inches.
Looking better?
02 Ranger FX4 L2
Old 12-28-2005
Never mind...local tire shop hooked me up sweet!
02 Ranger FX4 L2
NedoMedo
02-23-2012 05:04 PM
sutto51
04-15-2008 11:19 AM
BananaEdge
04-03-2006 06:51 PM
afi_pilot85
04-05-2005 01:30 AM
Bigwill41
07-03-2004 01:50 AM
Quick Reply: Wheel size help.
