4x4 problem
Old 06-03-2006
gadabout1018's Avatar
4x4 problem
i was playing in the sand hills and when i went to put it iin 2wd it made a continus click sound(like it does when you shidft form 2wd to 4wd) but it did it like 5 times. Now when i drive my 4h and 4lo light blink, and the truck will not go into 4x4. I have an electric shift (the one with the **** next to the radio). Any ideas what hte problem is, or how much $$$ to fix it?it is a 1999 ford ranger.
Thanks
Old 06-03-2006
Red_Ak_Ranger's Avatar
might wanna take it to the dealer. I had a similiar problem. Might be the auto transfercase.
Aaron
Old 06-03-2006
tonkaranger04's Avatar
get manual locking hubs from warn or something. my 97 did the same thing. it ended up taking like 10 mins to change the hubs out.
Old 06-03-2006
97 and 99 are mucho different.
Also, we 99'ers have REALLY CRAPPY FRONT HUBS. They do go out, and ford will replace them with newer hubs. Just to let you know, Pulse Vacuum Hubs suck.
Aaron
Old 06-03-2006
how much do hubs cost, and how hard are they to change.....i am 16 years old and always broke......and i dont have acess to much tools.....the truck is not under warenty so i wantto avoid the dealer at all posibility.
Old 06-03-2006
Junkyards would be your friend.
Old 06-03-2006
Aaron
word thanx man did not know that they changed the hubs. could he still get manual hubs or not. god i love this site i learn something new everyday
Old 06-03-2006
Yes he could. Let me do a search and i'll find some stuff on it.
Aaron
Old 06-03-2006
Here's a tech guide for tcase trouble shooting, kinda short but there's more on site.
http://www.therangerstation.com/tech...leshooting.htm
99 hub swap.
http://www.therangerstation.com/tech.../99hubswap.htm
this is how you would "manualize" the pre 98s. http://www.therangerstation.com/Maga...r2002/hubs.htm
Aaron
Old 06-04-2006
thanks...i guess i am just gonnna end up taking it to the dealer
Old 06-05-2006
is there a way i can make the 4hi and 4lo lights quit blinking
Old 06-06-2006
Cape Fear's Avatar
I would start by checking the shift motor and go from there. Heres a teardown guide.
http://www.therangerstation.com/tech...shiftmotor.htm
Old 06-06-2006
Kanoeking's Avatar
+1. Mine did the same thing. I tore apart the shift motor and douched out the grime. Works like a charm now!
As for manual hubs on a 99....well they do have them in the USA now...they are made by AVM of Brazil.
Clicky -----> http://www.therangerstation.com/foru...howtopic=45606
Old 06-06-2006
Ranger1's Avatar
I had the opposite problem one time. I could not get mine to go into 4lo it would click and shift in but then shift back out. Mine was an electronic contact that tells the truck what t-case is shifted into(something like that).
Old 06-06-2006
Kanoeking's Avatar
Yeah with the BW 1354e the range position sensor, located on the side of the t-case...I think there are 3 wires for it, is controlled/regulated throught the blue shift motor which in turn is controlled by a flip of a switch controlled by you... either one can go bad, and if it is the range position sensor you better flush your t-case and your tranny and all the coolers, ect. The sensor gets effed up by metal contaminent shavings in the atf. So I suggest pulling the sensor, looking for metal shavings and if you find then, flush the system and change filters.
Old 07-24-2006
ok, i finally saved up some money and took it to the dealer..they said it was the electronic shift motor and that it needs to be replaced....but is it $700 for parts and labor, does that sound right, i ma not sure how much a shift motor is supposed to call, i just got a voicemail, i have to call back in the morning and i was just wondering if i should go for it or if anyone thinks that is a little pricy
2003Ranger
08-24-2011 02:40 AM
ChargerOnDavins
10-03-2010 05:58 AM
1993_ranger
09-18-2008 09:22 AM
Bourgeois88
08-23-2006 09:25 AM
QWIKSNK
06-13-2006 01:02 PM
Quick Reply: 4x4 problem
