Auto Detailing 101 General discussion of auto cleaning and detailing. Learn tips and tricks to keep your Ford Ranger looking its best.
Vinyl underneath windows
Old 09-28-2006
due to the way mine behaved after it sustaned damage i believe they are metal with a rubber coating so that guy who painted his may have just sanded them down
Old 09-28-2006
feh728's Avatar
Once I get some time in my busy work/school schedule, I'll try cleaning it first. If that doesn't work I'll Try Armor All or something like it. If I still don't have any luck, Ill try takin them off and sanding then painting them. I'll repost with progress...unless someone beats me. Does anybody know how to take them off?
  #29
Old 09-29-2006
feh728's Avatar
UPDATE!!
I tried windex, and armor all. No help. I then took the drivers side one off and sanded and painted it. It looks so much better. no more splotches anywhere. One problem...I cant get the trim piece to stay on anymore! I still have a lil work to do. I think on the passenger side I'll just tape it off and paint it right on the truck.
Old 09-29-2006
Originally Posted by feh728
UPDATE!!
PICS!!!!!!
  #31
Old 09-29-2006
feh728's Avatar
I think I fixed it!
Freddie Hendrickson and Ranger-Forums accepts no responsibility if you hurt yourself or damage your vehicle or other property by following these instructions. Mod at your own risk.
Tools Required:
-Painters tape
-Newspaper
-Windex
-Rags
-Black Krylon Fusion paint
-1 hour of time
Here ya go everyone. I'd do a How-to but I am not privilaged enough to post there.
Before:
Tape Off everything you dont want painted:
Sand LIGHTLY!! I used 220 Grit (Important: make sure you feel the seal with your fingers. if you still feel bumps, keep sanding. You can have a smooth surface even though you still see the splotches. The paint will cover up the splotches. If it does not feel bumpy anymore, your ready to paint)
Clean with windex to get all the dirt off:
Painting:
I used Black Krylon Fusion because on the back it says it's made for hard vinyl as well as plastic.
After three coats and no more tape and newspaper, It looks a lot better. I don't know how it will stand up to abuse but until then, I like it.
Hope this helps!
Thanks for all the help everyone.
Let me know if you have any questions.
Old 09-29-2006
RockysFord's Avatar
It does look good, but the question is how long will it last....
Fusion is some good paint but i dont know how long it will last before it fades / peels / looks like crap
Rocky
Ecspecially on the weatherstrip for the window....if your window is down and you have you arm out the window all of the paint will crack from it bending down
  #33
Old 09-29-2006
nice job....now mask it all off again and add a couple coats of clear.....the Krylon Fusion is good if it has a good amount of clear on it....
Old 09-29-2006
feh728's Avatar
I put clear on the driver side and it kinduv melted in the Florida sun. It already looks like crap again. The passengar side is the one in the pics. So far so good for the passangar side but the drivers side is a different story.
Old 10-07-2006
edgey_04's Avatar
if all else fails use simple old peanut butter i used it in the past works well
  #36
Old 10-12-2006
jbomb212's Avatar
Originally Posted by anthony84_2004
There is deffinitly metal under them because I have a dent in one of mine, It would be nice to have them color matched, or even like a gloss black.
Yeah drivers side has dents cause of some large hail stones that hit it.............it is metal under the rubber
Old 10-12-2006
I believe they are EPDM rubber. 303 protectant restores them up pretty good, and so does Meguiar's vinyl cleaner.
I pretty much have taken to ignoring mine since they are so scratched from offroading.
SK
11-24-2011 05:17 PM
eric
2.3L & 2.5L I4 Tech
05-10-2010 06:10 AM
Jeremy102579
03-07-2009 06:13 PM
Jeremy102579
03-02-2009 11:43 PM
Carrottop688
06-07-2005 11:15 AM
Quick Reply: Vinyl underneath windows
