32's
Old 10-19-2006
telemaster1952's Avatar
32's
ok guys my parents are freaking out about whether or not zachs (redneckstone) tires will fit on my truck. right now it has 27's on and his are 35's i plan on putting a block on the rear(2") and the front putting on coil spacers. but will the tires fit......just want a second opinion
Old 10-19-2006
0RangerEdge2's Avatar
Well the 32's might fit with the lift. I think that's basically all he did. He should chime in soon about it.
Old 10-19-2006
BRENSRANGER's Avatar
i still wonder if 32s will fit my truck?
Old 10-19-2006
yea the 32's will fit with what you have planned....
Old 10-19-2006
if you put lift blocks on all around well that might work but i have no experance with the gen 2 and down....
and Brennan i will have pics of mine on 32x11.5x15 BFG eather tomarrow or late late tonight
Old 10-19-2006
gumby's Avatar
i dont think you will get 32's under it with only 2" lift. here is a pic of my old 86 longbed with 235/75R15's(29"). i lowered the coil buckets on the frame 2" which got 2.5-2.75" lift at the wheel and added a 2" block to the rear.
http://www.imagestation.com/picture/...3/fd4f9f55.jpg
http://www.imagestation.com/picture/...c/fd4f9f2d.jpg
Old 10-19-2006
ranger's Avatar
i have 32 son my truck and they fit but you will need alittle more lift than 2 inches. and youll need to pull your bedsides and front flares my bedsodes are pulles 4 inches and i have 6" front fender flares
Old 10-19-2006
Originally Posted by 04 EDGE
you could however find a sawzall and start cutting
i might just
its not like my truck is worth a ton anyway
Old 10-19-2006
ranger's Avatar
you might be able to fit the 32's with a body lift and the coil spacers and some 3-4 inch blocks and take off your front fenders.
Bodylift = 3 inches
Coil spacers = 2-2.5 inches
So you could get 5 or 5.5 inches of lift + you already have the 2 inch lift coils so they
should fit.
Body lift = $110.00 for a 89?-92 ranger on ebay
http://cgi.ebay.com/ebaymotors/1989-...ayphotohosting
Here are the coil spacers $105 they r 2" lift
http://www.suspensionconnection.com/...ml?id=4VLq38cV
Old 10-19-2006
04lvl2's Avatar
Just come up and get them lol, you know when the meet is and would good to meet ya nonetheless
Old 10-19-2006
i am going tommorow to a few local shops and see if they can help me(have them test it out on the truck) i will tell them that i am going to but more from them(spare, and the next set) an see if they let me try it out
i would like to come up and meet you guys
just to cracker barrel?
no OR time?
i want those wheels and tires!
mine just proved to me that they suck when i slid off the road during a ain storm
Old 10-19-2006
ranger's Avatar
oh and 32's on a gen 2look sweet!!!!!! if you do it you wont regret it trust me it is totally worth it!
Old 10-19-2006
casfz1's Avatar
come on up I will bring the sawsall. lol
chad
Old 10-19-2006
gumby's Avatar
2" coils plus a 2" coil spacer......that gonna be tough to get aligned.
i bet they would fit as is(2" coils) plus a BL, but it would be close. might take some trimmin
*edit, wow i tyep slow. 04 EDGE typed all that alingment stuff too while i was typin...
Old 10-19-2006
acully come to think of it i unstall this EXACT set i mean the set that i just took off my truck on a 1991 Hi rise package ranger its a 1991 ranger with a 2" lift kit from the factory and they fit fine. gosh how did i forget about that...
and also dont forget there 32x10.5 no 11 that helps here.. plus mounted on a 16x7 with out a HUGE offset at all...
Old 10-19-2006
putting a body lift on that old and rusted of a truck is not worth it, coil spacers is not really a great way to go on a twin I beam ranger, personaly i would go nothing more then a 1.5 inch spacer, it drops the beams down so far that you will need a 3 degree + or - alignment cams, you may never get the caster to come into specs. the proper way would be to at least get some drop brackets for the beams where that meet the frame then 2 inch spacers, i have seen these offered by themselfs and they are also adjustable for ease of alignment. total on that would be somewhere around 250ish, but then you will need rear 2 inch blocks and 4 longer shocks, plus a drop pitman arm.
so it would be best to just get a rough country 4 inch kit with shocks and a drop pitman arm for 500
acully Mark i have 2" lift blocks on my twin i beam with no radii's drop or pitman arm drop and its is aligned 100% in specs i beleave its a 2.25 cam used for aligning. i have the mechine print out if you dont beleave me i can scan it in...
Old 10-20-2006
gumby's Avatar
wouldnt that be a 4wd though? so it would be taller because its 4wd, and then taller again with the high rise package...
Old 10-20-2006
true but it was the same hight as my 2wd truck with just a lift block...
Old 10-20-2006
gumby's Avatar
and your 2wd truck is taller stock to stock than a gen1 or 2.
im jus sayin i dont think the comparison will help. i dont think they will fit his truck w/o more lift.
Old 10-20-2006
nope wont fit, just got that confirmed
im just guna put the money toward my friends old truck
Old 10-23-2006
Bhavesh's Avatar
So will it fit 30x9.5 or 31x10.5 with a 2" lift (coils in the front, 4x4 blocks in the back)?
I plan to get tires by winter, but I'm not sure whether or not to go with 30x9.5 or 31x10.5 on 15x7 wheels.
