4"Superlift 98-00 Owners got ???
For those of you who have the 4in Superlift kit on your 98-00 Ranger's I have a few questions.
I'm purchasing the above mentioned kit, and have some issue's that maybe some of you also ran into...for one my t-bars are sagging as it sits now, I know that the 4th inch for the kit is gained from cranking the t-bars. I have no idea what bars I have now, and because my truck was wrecked there is no data plate on the inside door...so should I just go for the stiffest bars? Which is what part #???if anyone has the #'S I would appreciate it.
Next when you install the kit, obviously it's a good time to replace the ball joints....I've read somewhere about MOOG having a nicer set of balljoints available for my year truck?Anyone have the #'s for that? Upper and Lower?
Did any of you run into any problems, that could have been avoided?Anything you suggest? Anything you guys replaced while you had the front end pretty much apart? Also how much longer are the Superlift FRONT shocks versus say stock bilsteins on a FX4. I purchased Bilstein's (FX4) from FORD PARTS not too long ago...and I'm thinking due to the 3 in difference in the steering knuckles that I'm outta luck??? Thanks ahead of time guys appreciate any help or advice.
PS ...anyone know where to get a Torsion Bar tools, without spending the friggin 104$? Any other tools?
RangerNVS
RangerNVS
here...
Originally Posted by rwenzing
#1 bars part numbers:
F67Z#5B326#FA Pass side bar 1stfordparts price $37.72
F67Z#5B326#FB Drivers side bar 1stfordparts price $37.38
all you need is a pulley puller or 2 prong puller. you can rent one from autozone
torsion bars.. .you prolly have 1 rating bars. maybe b, 1 is the best... and zach has posted the part numbers.
you have to run the superlift shocks they are longer.
balljoints..
balljoints..
FWIW, I just did a Google search on the part numbers and this appears to be the situation. Note that these numbers are for with Rangers with torsion bar suspension ONLY (98+ 4x4, 2000 Trailhead, 2001+ Edge).
DS one-piece UCA 98~2006:
(MOOG K8708T):
UCA w/replaceable/greasable ball joint
PS one-piece UCA 2003 1/2~2006:
(MOOG K80068)
Similar appearance to K8708T above but with slightly different ball joint offset.
PS 2-piece style ball joint carrier only 98~2003 1/2
(MOOG K8710T) :
Carrier w/replaceable/greasable ball joint
Note: this part is discontinued and may not be available. The entire 2-piece PS UCA assembly can be replaced by the 1-piece K80068.
Lower ball joint only 98+
Greasable, fits DS and PS
(MOOG K8695T)
Outer tie rod ends
(MOOG ES3461)
(MOOG K8708T):
(MOOG K80068)
(MOOG K8710T) :
(MOOG K8695T)
Outer tie rod ends
(MOOG ES3461)
on a stock ranger the balljoints are part of the upper control arm.
when you get the moogs it comes with the arms and the moogs can be replaceable after that.
no matter what option you have to get new upper control arms to replace the upper ball joint.
if and when you replace them you will need an alignment.
also you will need an alignment after the superlift install. make sure you get the torsion bars adjusted to an even height side to side in the front before the alignment.
blue_oval
1" & 3" Body Lifts
29
01-24-2010 07:41 PM
For Sale: ATTN: SUPERLIFT OWNERS! (CA)
08XLT4x4
36
12-20-2009 06:01 AM
shadow905
173
08-12-2009 05:17 AM
