Truck running BAD help please.
Last night while drive my transmission starting shifting like it was possessed or something. After driving further I thought maybe this isn't a tranny problem I thought it could be the Throttle Position Sensor. Then my Check engine light came on. I checked the code and it is a code for a pedal position sensor. My question is what is this where is it and where do I get a new one?
It's right on the throttle body, Bryan. On the one side, your throttle linkage connects to the throttle body, and on the opposite side the TPS is fastened on. I think it's just a couple of screws and a connector and it comes off.
Pull your battery for 20 minutes and let your PCM reset everything as it may have some bad data in the tables after running off kilter like that. You can leave it off while you replace the throttle position sensor, then connect it back up and you should be good to go.
The TPS is the electrical equivalent of the "kick down" cable of yore. It provides a signal to the system about throttle position so the transmission controls can figure out how to sequence the shifting.
In a failure, a default strategy is used which is reported to provide very hard shifts, so that sounds normal for the problem you're having.
TPS=PPS, by the way. There's only the one.
If it's the sensor and not a cable/connector problem, you can fix it in the parking lot of the store you buy it so you don't have to drive home that way.
I replaced the TPS in the parking lot of NAPA. It is nice to fix such a horrible problem with a Philips screw driver and it only taking 5 minutes. I mean the way the tranny was shifting I was thinking I might end up on the side of the road last night. So you would think such a terrible feeling would be a hard fix. But no changing a TPS is easier than doing an oil change.
Originally Posted by WholesaleMN.com
and just think, if you would have brought it into the shop you would have been charged for .6 hours of labor :) Good work, Glad NAPA had the stuff.
Oh yeah I only go to the shop if it is a last resort and it is something that is not time effective for me to fix.
I really cannot think of anything that would result with me taking my truck to the mechanic.
LayingFrame89
Ranger Products, Company, & Member Reviews
34
12-01-2007 06:59 AM
ranger
32
07-31-2007 11:50 AM
