Alternator pulley nut, which way to get off???
Old 03-06-2007
pushdeck's Avatar
alternator pulley/efan/pulleys install off on
Is the alternator pulley nut reverse thread or not? pulley slipping when I threw a pipe wrench on it and cranked witha socket, not enough room for an impact wrench either. Anyone have any suggestions?
Thanks
Old 03-06-2007
graniteguy's Avatar
its regular "lefty loosey". take it off if needed to use an impact gun. it's only 3 bolts.
heres a write up:
http://stuffforyourranger.com/How_To...ulleyswap.html
without the impact its gonna take a hammer and chisel.
Old 03-06-2007
graniteguy's Avatar
if you're not worried about saving the old pulley then put a visegrip on the pulley to hold it. impact makes it EASY though.
Old 03-06-2007
pushdeck's Avatar
Thanks a ton, didn't even think about pulling the alt, but yeah, air ratchet wouldn't do it and need teh nut fot he new pulley, so its coming off, I'll post in a sec and let you know if it worked. Thanks again!
Old 03-06-2007
pushdeck's Avatar
Got it, thanks. Now working on the efan.......
Old 03-06-2007
graniteguy's Avatar
cool(literally). you"ll notice that something just became "right" about your truck when it's all in.
Old 03-06-2007
pushdeck's Avatar
Tested and worked great, fan came on with ac, and also when the the temp sensor was tripped (haven't set temp yet, gonna do it at work with a temp. gun). The pulley make it idle lower and quiter as well, noticeable power gain (not a ton, but then again, its not tuned yet, hopefully get a buddy to do it this weekend mabye).
Well, feeling sicker by the minute, I'm hitting the sack..........
Thanks for the help everyone......
Old 03-06-2007
DCRVP's Avatar
I loved my pullies when i got them i just need to get a gatorback belt then ill be really happy
Old 03-07-2007
pushdeck's Avatar
Ok, tested it out a lil more extensively today (work and back) and everthing works great , just need to set the temp on the fan (guy at work is bringing on in on Fri.). I noticed the difference a little more today, it doesn't struggle/work as hard it seems to accelerate or hold speed. Also, punched it today at 40mph and it surprised me with a nice lil kick . Oh, and then the exaust sound sick now, real garthy and deep compared to what it was.
This is a must do for any 3.slow owner , only like 321 (203 for pulleys, and 108 for fan, and 10 bucks for some fuses(30amp, and add a fuse 10ampX2)) with fan, pulleys, and better fuse set up. Also, a cone filter like I have with a moded stock box or cold air intake helps.
Will post the MPG once this tank is done (~1 week)
Got a lil smiley happy, happens........
JoshMcMadMac
OLD - Engine & Drivetrain
08-18-2010 11:04 AM
Metro55
08-01-2009 07:02 AM
Goodysgotacuda
05-17-2009 12:58 AM
pastfinder
05-11-2007 11:03 AM
james13f
Audio & Video Tech
06-15-2005 02:06 PM
Quick Reply: Alternator pulley nut, which way to get off???
