How NOT To: Eliminate 3.0 Belt Squeal
This is a thread to document how NOT to diagnose and fix a belt squealing problem on a 3.0.
About 2 months ago my belt began to squeal and became very annoying. Being the idiot that I am I started with the expensive fixes first and moved my way down to the free fixes last. The squeal is now gone and I wanted to share my inexperience with others who might have this problem.
This is the order of events that took place to fix the squeal.
1. Replaced crank shaft, alternator, and water pump pulleys with 20% underdrive crank shaft and water pump pulleys and 20% overdrive alternator pulley. (why replace when you can upgrade?) Also replaced stock belt with appropriate length Gator Back belt.
SQUEAL BECAME LOUDER
2. Replaced idler pulley
SQUEAL MISLEADINGLY LESSENED
3. Replaced tensioner pulley
4. Cleaned belt and grooves of pulleys
NO EFFECT
5. Scarred the surface of the idler and tensioner pulleys with sandpaper
SQUEAL DISAPPEARED AND HAS REMAINED GONE FOR 2 MONTHS
To summarize:
Don't do what I did.
NO EFFECT
To summarize:
Pulley BEARING is Napa part number 6203-2RSJ. Taps easily in and out of each pulley.
I carry spare bearings and a spare belt.
Mine still squeaks on damp mornings (it's a Dayco belt- I know, "get a Gatorback", but I'd have to mail order it - no one carries Gatorbacks in my one-horse town).
Squeak goes away when truck gets warmed up.
Squealing,
When it rains or cold weather my 95 does this now, use not to.
When moving on the road I can push in the clutch and the noise stops, push on gas and almost always comes back . A lot of times it will stop after I push in clutch.
Have took off belt and tried all pullies, no issues that I could tell -alternater, fan, tension, idler...
No power steering.
Any other things to try ?
Will do the sandpaper thing next.
Thank you !
No power steering.
Thank you !
greenranger624
01-06-2016 07:00 AM
