04 EDGE's 2WD to 4WD
Old 05-14-2007
zainyD's Avatar
Looks like a pretty easy conversion since the Edge has the same suspension as the 4wd. How much $$ will you have into it when you're done?
Old 05-14-2007
jrpro130's Avatar
Originally Posted by 04 EDGE
so far i have around 150 in used parts, 50 for the 2 rotors.
i have 2 transmission options at the moment, first is replacing the output shaft and housing for around 250, (i have a friend that owns a transmission parts warehouse) but that will requier total transmission dissassembly. second option is a new take-out unit from a 2003 4x4 5R44E for $450.00 from the same guy. (its good to know people!)
i'm thinking the later of the two is the way i'll go, once i get the trans and Tcase it should be a one day project.
I would seirously consider this swap. I would do it w/ the superlift kit too though. I wouldn't go any lower b/c even right now my truck feels too low for how I use it.
I figure superlift 4x4 conversion is about a 3k dollar affair!!!
Old 05-16-2007
RazorsEDGE's Avatar
ok new update. seems the ABS pump and module are diferent. the 2x4 unit does not like the 4x4 front speed sensors. i got a 4x4 unit cheap from a local yard and will be installing it within the next few days. pics will folow.
What was wrong with it? brakes locking up or what?
Old 05-20-2007
got the 4x4 ABS pump-module installed and now a new problem, seems the instrament cluster does not like the new ABS unit!
going into to ford next week i hope for a "cluster re-flash"
the tech said he could flash it any way i want, so i think i'll have him fix my speedo for the larger tires and flash it for a manual transfer case.
would a 4x4 cluster fix the problem?
Old 05-20-2007
gumby's Avatar
im runnin a 2wd cluster in my 4wd. i doubt that will help out.
Old 05-20-2007
5speedin2.3's Avatar
the 04+ clusters are retarted, you have to program it to the computer.
to bad he doesnt have a 95-03, then he wouldnt have todo any of that.
Old 05-31-2007
use the upper driveshaft since it has a double cardon joint on 1 end......
Old 05-31-2007
curious why you didn't just get another automatic tranny that was already from a 4x4 truck? wouldn't that have been easier and probably cheaper
Quick Reply: 04 EDGE's 2WD to 4WD
