80,000 miles on drum brakes gets you this
Old 09-01-2007
casfz1's Avatar
This is what happens when you get lazy and wait 80,000 miles to do your rear brakes. I had to cut the passenger side drum off because it would not come off even with a pry bar and a hammer. The drive side came off with a little hammering and prying. The passenger side shoes feel out when I finally got the drum off. On with the pics.
Old 09-01-2007
ranger's Avatar
yea wow hmm metal on metal = grindage
Old 09-01-2007
LOL
I still cant believe you made it that long!
how does it stop now?
Old 09-01-2007
casfz1's Avatar
Man I can stop on a dime.
Old 09-01-2007
that is good.
didnt have to get new brake lines too did you?
Old 09-01-2007
casfz1's Avatar
no they came right out. all I had to do is put a line wrench on them a tap them with a hammer to loosen them.
Old 09-01-2007
nice!
bout time you fix that, but heck, i sold my 01 with 75k without ever changing the rear brakes
Old 09-01-2007
04lvl2's Avatar
Thats about what I expected to see lol. I bet it does stop alot better now Chad.
Old 09-01-2007
casfz1's Avatar
whats funny is they just started making noise this week.
The emergency brake arm was stuck in the shoe it wouldn't even pivot.
Old 09-01-2007
my truck has 95,000 on the rear brake shoes......doesn't make a single noise......they have been inspected 3 times when the rear axles were pulled once to install the new gears, once to install the new L/S unit, and once to check the gears/carrier......all within 5,000 miles ago........my gf's uncle did the work and he said the brakes looked great!
Old 09-01-2007
RockysFord's Avatar
mine looked the exact same at 40k miles..
Old 09-02-2007
I have almost 90,000 on the original rear brakes too. Hell, the front ones lasted about 60,000.
Old 09-02-2007
red_fx2's Avatar
haha ya i had the same problem with mine.. bu they had 74k on them.. caked with mud,water.. u name it.. it was in there.. haha.. i was stopping with my front brakes only for a while... needless to say i went through alot of pads...
Old 09-03-2007
5speedin2.3's Avatar
i was up at my dads work the other day and he pulled the drums off an 03 fx4 with like 20-40k on it and it was worse then that, the only thing i can think of is the rust builds up behind the pad and separates it.
Old 09-03-2007
wow thats pretty impressive
Old 09-03-2007
I've always been good at spending as little money on my truck as possible. I'm easy on my brakes and they last forever. It probably also helps that I'm not off-roading in mud or salt water. Same with tires. Almost 90,000 on the stock pieces of junk. I wish those would finally wear out because I hate them. But I'm too cheap to replace them when they don't need it yet.
Old 09-04-2007
my rear drums went 105k before i took it to the shop to get fixed
Old 09-06-2007
We changed my rear drums and shoes last year, about 110k on them and they didn't look as bad as yours
Old 09-06-2007
Mine are fine at 79,000, I actually just checked them before we went up north for labor day...
Old 09-06-2007
yeah but he is running bigger tires and gets the truck dirty... makes a big difference when you add some sand and dirt in the mix.
Old 09-06-2007
Mark98xlt's Avatar
I had the same on my 98 with about 85k, same issue with getting the drum off as it was stuck do the the emergency brake was stuck. had to beat the drum off.
Old 09-06-2007
I see, well I travel down many dirt roads (they get muddy when it rains) but nothing like you 4x4 guys do....
Old 09-06-2007
this was some soupy stuff, nothing like dirt roads.
Old 09-06-2007
LOL.... I know, I was just messin....
Old 09-25-2007
Matt3203's Avatar
it really depends on where you live, if you live in the mountains then your gonna use your brakes a whole lot more then say florida
Quick Reply: 80,000 miles on drum brakes gets you this
