How to get more light output??
Old 11-29-2007
cory07ranger4x4's Avatar
I want both my headlights and foglights to put out more light on my 07 ranger 4x4 xlt... I would get a pair of aftermarket foglights for the front but I don't wanna get a brush guard or bull guard on the front so I don't wanna mount the foglights with the stock bumper... So what bulbs can I put in my foglights and headlights to get a lot more light? What brand and stuff? Is it a big difference in light output?
Old 11-29-2007
Machine090767's Avatar
if your fog lights use the 9145 bulb (42 watts) you can upgrade to a 9005 bulb (65 watts) as for the headlights, you could just go online and find a 9007 thats higher wattage, something higher than the stock wattage. but, don't go too high, or you'll run the risk of housing meltage and wiring damage.
Old 11-29-2007
bruiser's Avatar
HID's
Old 11-29-2007
well if I was open to foglights, I want 150w but will they work for stock wireing and stuff??
Old 11-29-2007
gopher18's Avatar
I wouldn't...
Old 11-29-2007
well what are my options if i'm willing to get a pair of aftermarket foglights?? I really miss my foglights on my tacoma...
Old 11-30-2007
tekrsq's Avatar
Are you looking to run them on the highway? If so, you can't run a 150 wt anything on the street.
Old 11-30-2007
ns_red7's Avatar
Replace your headlights (9007) with silverstars. Do your fogs too (9005). They're noticeably brighter than stock for not a whole lot of $$ compared to good hids.
You can always add higher watt lighting later, but don't put more than 55-60watts through the factory wiring, it's waaay too mickey mouse.
Also you can get the light mount tabs, there's 2 holes in behind your bumper that they mount to.
Old 11-30-2007
^^ What he said ^^
I've had this setup for years and it works flawless. Much better than stock and without giving your wire harness a meltdown.
NO!!! None of your stock wiring will support plugging in 150 watt lights. It will meltdown faster than you can get from 0-60. I'm not even sure you can buy a 150 watt 9007 or 9005 replacement bulb to begin with. If you are talking add-on off-road lights, then you would need to use a relay and substantial wiring to power them.
Old 11-30-2007
garryyjr's Avatar
good info.. i was wondering the same...
Old 11-30-2007
well I would want the foglights offroad only... like the 150w or whatever... Then brighter bulbs for my stock stuff for onroad.
Old 11-30-2007
ns_red7's Avatar
If you've got $$ to burn on bright off road lights, http://www.lightforce.com/
Tony Soprano had them on his suburban.
Old 11-30-2007
fog lamps are useless and illegal over 55 watt, so the 65 watt bulbs are pushing it. don't go higher.
04RangerDave
44
05-27-2012 07:09 AM
Tys 4x4 FTW
09-30-2010 05:47 PM
DIPINTHEMUDD
36
01-12-2007 02:17 PM
n3elz
35
12-06-2006 05:06 AM
Gearhead61
05-28-2005 12:50 AM
Quick Reply: How to get more light output??
