Gearing help please
Originally Posted by 04 EDGE
so your gonna use a 14 inch wide wheel?
good luck
good luck
Those are WAY too wide for a Ranger no matter how much lift you are running.....you would have to do some major modification......not to mention that you wil have to run atleast a 15.50" wide tire for those wheels
yea...4.10s are fine for 32s.....that's my set up. Probably cheaper to get junkyard axles if you are like 3.73 or 3.55. You can find out your gearing by looking at the door tag or on the rear axle tag. Therangerstation.com has a good tech library.
As I stated in another one of your 10 threads....you will NEVER be able to air those suckers down.
isaaccoburn96
21
03-07-2015 11:16 AM
