How-To: Determine your Ranger's calibration code
Old 02-12-2008
redranger4.0's Avatar
Mod:Determine your Ranger's calibration code
Difficulty: 1/10
Time: N/A
Author: Bob (rwenzing)
Sometimes it is valuable to know your factory calibration code. You would need it to buy a tune for a flash tuner like those from SCT. It might also help while junkyard shopping for a replacement processor.
1995~2006 Ranger 104-pin EEC-V (single connector):
Look for the label on the PCM which is located in a slot in the passenger side firewall. The code may also be found on a sticker near the passenger side fender (as shown) or elsewhere depending on the year. The code is 4 characters and varies based on the year, engine, transmission, drive, emissions region, etc. of your truck. In this example the code is GDM2; yours will probably be different:
2007+ 170 pin PowerPC processor (three connectors):
Since the code label is often hidden, it may be necessary to pull the PCM out of its niche in the firewall. In this example, the code is BNM2; yours will probably be different.
2k1offroadpkg
02-12-2009 02:29 PM
Hot Wheels
Wheels & Tires Semi-Tech
07-06-2008 07:53 PM
V8 Level II
01-09-2008 09:33 AM
BBBB51
01-29-2007 08:02 PM
Swoop1156
16
12-02-2005 07:44 PM
Quick Reply: How-To: Determine your Ranger's calibration code
