need help with wheel bearings/axle shaft
Old 02-28-2008
RedPowerRanger's Avatar
Icon8 need help with wheel bearings/axle shaft
OK, first of all this is for my 1980 Toyota project truck.
I am trying to change out the wheel bearings and seals. I have pulled out the axle shaft, removed the snap ring.... but that is as far as I have gotten. I can't seem to get past the old retainer and bearing. won't budge. Following the Chilton manual, it should just come out
What should I do?
Old 02-29-2008
OTRtech's Avatar
Quote :
What should I do?
Ummm ...Post your question in a Toyota forum ?
Old 02-29-2008
Wow, thanks for bringing absolutely nothing to the table.
Old 02-29-2008
you might have to get a slide hammer to get the bearings out...i would assume they are somewhat of a press fit...
Old 02-29-2008
mossyoak03's Avatar
is there any way you can get them with a bearing puller?
Old 02-29-2008
I will look into a slide hammer and bearing puller
thanks
Old 02-29-2008
any bearing puller that I know of won't fit around the axle shaft
This thing is kicking my butt
Old 02-29-2008
buckgnarly's Avatar
If it's anything like the D44 shafts on Jeeps, you have to crack the old retainer off. You drill into it, but careful not to go through to the shaft. After you have the hole, take a cold chisel and crack it in half. Bearing comes off after that.
Like this.....
http://www.stu-offroad.com/axle/d44/d44-1.htm
Old 03-02-2008
I finally got it.
I used an angle grinder to cut off the retainer, then banged the S*** out of it until it finally popped loose.
now just waiting for the new bearings and seals to be delivered, got a lock rite locker to complete the rear axle
Old 03-11-2013
kalifornia's Avatar
I can pull my rear wheel in & out HELP
delete
staracaster
07-02-2015 01:54 PM
staracaster
07-01-2015 08:16 AM
staracaster
06-18-2015 12:55 PM
MCM5595
12-22-2011 04:31 AM
Prangy
12-08-2011 10:37 PM
Quick Reply: need help with wheel bearings/axle shaft
