How-To: Replacing Instrument Cluster Lights
Old 05-26-2008
Takeda's Avatar
Level I Supporter
Follow these instructions, and pictures to change the instrument cluster bulbs on a Ranger (mine is a 1999, I'm not sure on what years will be the same).
It takes 6 194LL light bulbs, go ahead and change all 6 while the instrument cluster is out.
Step #1 Using a 7mm socket, remove the 2 screws holding the radio bezel
Step #2 Pull radio bezel out slightly
Step #3 Using 7mm socket, remove 4 screws holding kick-panel below steering wheel. Note: 2 screws are under hood release handle
Step #4 Drop hood release bracket and pull kick panel out
Step #5 Using 8mm socket, remove 4 of the 5 screws holding kick panel metal brace
Step #6 Just loosen 5th screw in kick panel metal brace enough to drop brace to clear bottom 2 screws in instrument cluster bezel
Step #7 Using 7mm socket, remove bottom 2 screws in instrment cluster bezel
Step #8 Using 7mm socket, remove top 3 screws in instrument cluster bezel
Step #9 With tilt steering wheel, drop to lowest position. Also pull tranny shifter to "1" position (if automatic). Note: Make sure emergency brake is set! Pull Instrument cluster out from the
top
Step #10 Using 7mm socket, remove 4 screws holding instrment cluster
Step #11 Gently pull instrument cluster out from the right side, far enough to reach the 3 electrical connectors. Electrical connectors have release tabs to push in before pulling
connectors:
Step #12 Instrument cluster lights are in black caps. Turn caps counter-clockwise to remove light bulbs
Step #13 Light bulbs pull out of black caps
Reassemble in opposite direction
The following 4 users liked this post by Takeda:
fernando8877 (01-18-2022), Georgeandkira (04-06-2021), JEide (03-03-2024), jockodog (02-18-2020)
Old 11-06-2008
95-09 is what this how-to covers.
Old 03-06-2009
Takeda's Avatar
Level I Supporter
I meant to post a night shot of the "stock" instrument panel:
Old 03-07-2009
GrafixGuy's Avatar
its fixed for the most part, now the far left is out, I'm not gonna bother with it anymore...
anyways, here's the view of the 04+ clusters for you guys doing replacements...
Old 01-06-2012
ezernut9mm's Avatar
another helpful post. thanks guys.
Old 01-12-2012
Rangerman415's Avatar
what are the other types of bulbs in there? Because I think it's just 194 and one other type (the white ones) right? Thanks alex
Old 02-10-2012
quickslvr8000's Avatar
awesome write up just did it easy as pie thank you!
Old 02-22-2012
firebirdude's Avatar
I'm wondering the same things. Though my Ranger is a little older (97), it uses two different bulbs. 194 for general gauge backlighting and many tiny bulbs for each of the service lights (ABS, Check Engine, Seatbelt, etc,etc). Anyone know what size these tiny bulbs are?
EDIT: Additional searching found me a thread on another forum where someone said they are 74's. They certainly look correct. Anybody?
Old 02-22-2012
You are correct I did a swap a couple weeks back, the other bulbs are 74s.
Old 02-26-2012
Thanks man. It was so straight forward. I used the 194's cause they were the highest rated lights at the store.
Old 02-26-2012
Yeah it's super easy! No problem brotha!
Old 03-29-2012
Robuilt's Avatar
thanks for the great write up. knocked this out in ten minutes
Old 04-01-2012
ford93's Avatar
i tried to do this in my 2008 and when i pulled the cluster it didnt have 194 it had these little bulbs.
anyone know what bulb this is and where i can get a led for it?
Old 04-01-2012
SteelDirigible's Avatar
it's one of these. not sure which one.
http://www.superbrightleds.com/cgi-b...nstrument.html
Old 05-08-2012
brian90744's Avatar
the wedge style bulb are #74 for late models 2006 up. from superbrightLEDs use 74xHP3
brian
Old 05-31-2012
vaquero's Avatar
http://www.ebay.com/itm/190671182260...t_12094wt_1270
Just bought these will try to get them in the dash as soon as they arrive and get pics for you all. Should look pretty cool when done
Old 05-31-2012
flipper66's Avatar
my 92 was all 194s........ some where in the neighborhood of 12 for all the bulb positions. I keep a stock of them for all of my cars so I have LEDs in all of them now. Looks so much better.
Old 02-24-2013
texrat's Avatar
Great instructions and helped us solve our problems with burnt-out bulbs in our 2000 Ranger. Thanks!
Unfortunately, during the bulb replacement something broke with the shift indicator, and I did not catch it until the dash was reassembled. Something else to fix now, and this one I really don't like :(
Old 04-20-2013
mazdaddy's Avatar
Great info thanks.
Old 12-08-2013
BigJosh99's Avatar
I have a 1999 Ford Ranger 3.0l v6 and i need to know how many bulbs i need for my instrument cluster. I do not have a rpm gauge. So if someone could tell me what i need that would be great thanks!
Old 12-08-2013
Still should be 6. Buy 6 or 8 and return any extras. Or keep them around....your glove box, dome light, front corner lights, and license plate lights all take the same clear #194 bulb as your gauge cluster.
Old 11-20-2014
mbutts4901's Avatar
Wow, fantastic write up and photos! Worked exactly as you stated on my '99.
Old 11-20-2014
Dewey's Avatar
@THE_ALMIGHTY_E4_RANGER
Old 12-23-2014
1998 Ford Ranger instrument panel illumination LED polarities
Here are the LED polarities for my 1998 ford ranger.
https://flic.kr/p/qvUC9i
Old 06-14-2015
Ok So I don't think my Dash lights are the problem for my truck, 98 ranger. They all went out at the same time and weren't really showing any fade. I do not have fuse #11 under the hood so that shouldn't be the problem if it has worked the whole time. I also replaced fuse 26 in the drivers side door. I need to check the other fuses in the glove box.
If it is not the fuses or the bulbs, what is the name of the relay I need to replace?
Quick Reply: How-To: Replacing Instrument Cluster Lights
