auto to manuel help
auto to manuel help
hey guys and girls i have a 3.0 auto and i had a really bad leak and thought i found it and solved the leak truck was driving fine and went offroading which i will have pics and vids soon there was some awesome stuff and i was wheeleing and doing everything my buddies trd on 35's did it was awesome it was getting pissed cause he always talks smack but any way my tranny is slipping really bad i talked to a mechanic "who i know" explained it to him and he said it will need to be rebuilt... so if im going to spend that kind of money i atleast want a stick i hate my auto so just wanna know how hard it is to convert and i also have access to a stick but its out of a 4.0 and wanna know if that will work please let me know my truck only drives in 2nd and its really anoying...
Punctuation please...looks like babble.
The swap is pretty straight forward. Actually....quite easy imo. There's a few threads regarding this subject of the auto to manual swap.
Did one a few weeks back to a buddy's '98 4.0L 4x4 ranger. He blew the trans on a tues, had all the parts on hand by thurs morn, auto trans and everything out on thurs night, test drove the truck as a manual on fri night. And only working nights on the truck. Everything works as it should...but still has the auto trans wiring harness, needs the manual harness to get rid of the 'od' flash, and ability to use the '98 4.0 4x4 manual trans ECU/PCM.
You'll need:
M5od-r1 trans(i reccoment a M5od-r1hd found behind 4.0L SOHC engines)
clutch/brake pedal assy
slave cyl
master cyl
'00 3.0L manual trans ECU/PCM
Clutch Kit(disc, pressure plate, alignment tool, pilot bearing)
Flywheel
Possibly a new starter?
You'll likely need to replace that auto trans harness with a manual harness(ECU to trans harness i believe).
You'll need:
slave cyl
master cyl
Flywheel
ah sweet guys. yeah i found the other posts, using the search button haha. also found a tranny at a local yard he wanted 550 for it, seemed like alot but it was also the only place i called... but i fixed the problem the trany had a little too much fluid after topping her off so once it all leaked out it was fine. now i just need to fix the leak which will happen this weekend. im still going to swap her out i just put a post on craigslist for my transmission for 800 bucks so hopefully it sells fast so i can have a manual. does 800 seem like alot or too little well let me know.
hope that is a little better, english was my worst subject in school, which is probably why i swing a hammer for a living, haha...thanks for the replies too guys i really appreciate.
dang well thanks for the help guys im going to order a body lift right now so i dont have to cut the Y pipe, for the manual trans. i guess i will put my auto trans for 500 im still going to switch to a manual though so i can probably get all the parts right now cept for the trany that will have to wait till i finish this job im on right now and get some money.
haha i know crazy huh it was only like that in the mountains in the shade. and im sure its all gone now there was a random very cold couple days befor we went up. yeah i love the bumper its an 02 off my roomates truck that has not been touched really since i met him he wants a prerunner, i keep telling him to build a sick rock crawler out of it, but he wont...
next time i go wheeling i will have a bl unless i get a wild hair in the next couple days, hahaha.
eXtreMe579
03-11-2012 11:08 AM
