cat armor
cat armor
has anyone made a bar or a plate for the 4.0's to protect the cat? i whent wheeling and smashed my cat resulting in destroying it and now i need a whole new Y pipe and main cat. is it possible to maybe bolt a bar across the botom of the truck where the cat is to prevent this from happeing again?
i don't know if it's my rcd or what but i've never had any problems with that cat....actually it's the only one left on my exhaust setup. bwahahah.
if you've looked under there though and are replacing the y and cat yourself, i'm sure you can come up with something. where there's a will, there's a way.
the only thing im worryed about is if i do put a bar from frame rail to frame rail or even a cage wont i smash the bar or cage into the cat and be in the same boat anyways? im more thinking along the lines of getting a bar and mounting it from rail to rail but theres no where in the middle to support it.
on
Hmm. That's a good question. I've probably hit mine before but never damaged it. If you're good with metal work I suppose you could make a skid similar to the gas tank one that spans from the front crossmember back to the transmission crossmember, along with some supports the the frame rail(s) on the sides for support.
on
Not exactly sure, sorry. Probably anywhere from around 98-2004 would be very similar. Someone else may know for sure. The ones I got bolted right up exactly to existing holes in the frame and crossmembers, I used my own bolts though.
According to this thread, it seems that any 97+ will fit: https://www.ranger-forums.com/forum2...ar+skid+plates
