Zabeard's Front 3link and Coilovers (Done)
Old 11-07-2008
Basically the other thread is so long and its already been SAS'd
I am converting from XJ/TJ Long arm system to a custom 3 link setup. Ditching the 5.5" XJ coils for 14" Ballistic Fabrication 2.125" coilovers.
Specs
Lower Link
2.63" Ballistic JJ on the axle and frame end of the lowers.
Roughly 41" Long (eyelet to eyelet)
Passenger side upper Link
2.63" Ballistic JJ on the axle end and a 7/8" - 3/4" Ball Chromo Heim on the frame end
Roughly 31" long eyelet to eyelet
10" of separation of the upper and lower links at the axle end.
Plan is to have 6" of up travel and 8" of down 60/40
I am also putting on a Currie AntiRock sway bar, I had one, it wont work with the width and steering setup so I bought the full size one 44" with 20" arms and I will make that work.
During the change I will be replacing the panhard with a longer one because of the added room, hopefully that will also improve the front suspension.
Some may ask why I am doing it, list of reasons
Caster change within travel
Rubber bushings suck
more accurate spring rate
better travel
I'm sure there are other reasons.
I have a big parts list, I will post that later.
I have all the parts in possession except the coilovers. I cant order those until I get my truck weighed.
Old 11-07-2008
bad *** let me know if you want a hand
Old 11-07-2008
This should be interesting. Good luck with the install.
Old 11-07-2008
redranger4.0's Avatar
now your just making me look bad. Your "technically" going to have 2 SAS's done on your truck before my one......
Old 11-07-2008
EdGe_wannabe's Avatar
Good luck Zach, although I know it'll turn out quite nice!
Brenton
Old 11-07-2008
hop to it skippy
Old 11-07-2008
I'm trying
Old 11-07-2008
oh yeah, any questions or insight into the project is always welcome!
Old 11-07-2008
Why so short on the upper link compared to the lowers?
Old 11-07-2008
http://www.youtube.com/watch?v=YoAu-gPPktQ
Watch that video, its pinion angle for dummies type of stuff. It shows a bunch of different types of 4 links, but its the same thing for what your doing. The short upper causes alot of pinion change, if you want it to remain flat through out the travel you need to keep the links as even in length as possible.
Old 11-07-2008
JoshK's Avatar
You weren't kidding when you told me you had the parts LOL
Old 11-07-2008
darkstar_420's Avatar
i just wanted to comment on your profile pic there, im pretty sure that you may be stuck
Old 11-07-2008
Shaklakan's Avatar
no kidding or he just plowed through with 4wd.
Old 11-07-2008
based off a few articles that i have read the upper should be 75% of the lowers.
when i get home i will look at my bookmarks and show you. that is really the only reason.
I already bought the DOM, but it is a little bit long.
Old 11-07-2008
sweet video, really helps you understand them
Old 11-07-2008
Have you plugged anything into the Pirate 3link Calculator?
http://mysite.verizon.net/triaged/fi...kV1.0bBETA.zip
Just seems like from a pinion travel stand point you want them closer in length. Specially if your going to be pulling a lot of travel because the pinion will rotate a lot through out.
Old 11-07-2008
PS. What are you doing with your current long arms?
Old 11-07-2008
I sold my long arms to HighrollerII
I have messed with that calculator some but i will some more too before i get too far.
Old 11-07-2008
I took some pics this afternoon.
$750+ worth of parts
Btw this is one of the best tools I have got. I just hole sawed a 2" x.25 wall DOM with a 2.63" Hole saw extremely easy. Its awesome, worth every penny
Old 11-07-2008
casfz1's Avatar
I see the rest of the parts finally got there.
Old 11-07-2008
ranger's Avatar
what axle is behind all the parts?
Old 11-07-2008
Ford F150 8.8
Old 11-07-2008
MMmmmmmmmmmmmmmmmmmmmmmm
Old 11-07-2008
Tubing notcher ftw. Cool stuff Zach.
Old 11-08-2008
Shaklakan's Avatar
Damn all those parts just scream sexiness!!!
Quick Reply: Zabeard's Front 3link and Coilovers (Done)
