Sponsored by: DashLynx
Motorcraft > Seafoam
Old 12-11-2008
Toreador4x4's Avatar
As most of you know i work at a Ford dealership and i like to see what sweet Motorcraft stuff they sell...
So today i purchased the Motorcraft version of seafoam, called "Motorcraft Carburetor Tune-Up" and i used it in my truck as you would use seafoam, except after you let it sit 15 minutes and re-start it, you pour the rest of the bottle in. It is far stronger than seafoam, and produced better results.
I have used seafoam and it is a great product, but i think im sold on the Motorcraft version now, and it is only $4.90 my cost, so it is half the price of Seafoam.
Motorcraft Carburetor Tune-Up (Part Number PM-3)
After i put it in my truck, being a seafoam virgin, it smoked in excess of 20 mins at 2000rpm. I took it on the E-way on my way home from work and opened it up and it pulled alot better from 0-80 and the idle is better as well
EDIT!!!
*It is highly recommended that this product be purchased at www.stuffforyourranger.com *
Old 12-11-2008
gumby's Avatar
agreed. the motorcraft stuff is much better than seafoam.
ran a can thru my turboranger back on 02 when i worked at a dealer still. carbon buildup = decimated!
Old 12-11-2008
whippersnapper02's Avatar
I may have to try this.
Old 12-11-2008
I'll have to go by and pick some up.
Old 12-11-2008
Another tech i work with said to do it 3 times and then change the oil, but im a little weary of this....Gumby?
Old 12-11-2008
gumby's Avatar
if i did it three times, i would definitely change the oil afterwards, haha
i didnt feel any need to do it again after the first time, and im still runnin the same motor with over 200K and 20psi of boost. havent even had the head off....its no miracle magic treatment or anything, but i dont have any detonation problems either, which would be a possible symptom of carbon build up again.
Old 12-11-2008
03XLT's Avatar
Found this TSB:
FORD:
1990-1997 AEROSTAR
1990-2000 EXPLORER, RANGER
ISSUE
Some vehicles equipped with the 4.0L OHV engine may exhibit an engine noise which may be perceived by the customer as a piston/connecting rod bearing knock. This carbon knock is heard only under load during the drive cycle. Carbon knock is a customer drive duty-cycle phenomenon that cannot be repaired with an engine exchange. This may be caused by carbon build-up within the combustion chamber.
ACTION
Verify condition. If normal diagnostics fail to correct the condition, de-carbon the combustion chamber to help quiet the carbon knock noise. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
1. Use Motorcraft Carburetor Tune-up Cleaner PM-3.
2. Carbon removal:
a. Disconnect canister purge line from throttle body.
b. Attach a vacuum line to the canister purge port.
c. At hot engine idle, allow the engine to ingest 1/2 to 2/3 of a can of Motorcraft Carburetor Tune-up Cleaner. Use caution not to ingest too quickly due to potential hydro-lock issues.
d Shut engine off and allow it to soak for one hour.
e. Start engine, allow engine to ingest the remainder of the Motorcraft Carburetor Tune-up Gleaner.
f. Remove vacuum line and re-install canister purge line.
g. Road test vehicle at 3500 RPM for 2-3 miles.
h. Repeat above procedure two times for a total of three times.
i. Change oil and filter.
3. Review the customers' driving habits
. The recommended drive cycle should include daily periods of engine operation above 3,000 RPM, such as a brisk acceleration from a stop position. This will break/burn the carbon off the piston head.
4. Use regular unleaded fuel, 87 Octane. Mid-grade and Premium fuels may increase the probability of carbon buildup, leading to a knock noise.
Old 12-11-2008
Rangerkid's Avatar
Justin, grab me a bottle please.
Old 12-11-2008
give me $5 and i will...txt me or stop by my work tomorrow
Old 12-11-2008
Is this product available to the public?
Old 12-11-2008
this product is available, go to the dealership and give them the part number
Old 12-11-2008
i should do this on my ranger. where are you pouring it in at?
Old 12-11-2008
gumby's Avatar
suck it in thru a vacuum hose.
Old 12-11-2008
same because I have a supercharger? I can just unhook the boost gauge and let it suck it in?
I have never used Seafoam or anything in 110K miles.
Old 12-11-2008
03XLT's Avatar
I'd like to do it too. My truck pings in high gear on a pull (uphill). I think I baby it too much, and that builds up carbon deposits on the pistons. That TSB says in a roundabout way to run the guts out of your truck periodically. :)
Old 12-11-2008
Takeda's Avatar
Level I Supporter
The brake booster vacuum line works good.
Old 12-11-2008
gumby's Avatar
i would find a vac source after the charger. doubt you wanna be suckin liquid thru that headunit.
Old 12-11-2008
ha! good call
brake vacuum line works for me.
Old 12-11-2008
Lord Of War's Avatar
Sounds like gold. If it works better then Sea-foam then we are all in for a treat.
Old 12-11-2008
yes...sorry i forgot to say i did it in the vacuum line from the brake booster. Im gonna do it on my dads 4.0 OHV in a few days. if you guys cant get it ill just order a case and youll pay cost+shipping but i dont see why you couldnt get it
ALSO!!! if you have a 3v 5.4 that the plugs break off when you remove them (like every 5.4 3v does) pour this miracle liquid down the spark plug holes over night before removing them. the shop foreman swears by it and hasnt broken one off yet
Old 12-11-2008
Yeah I pulled that up when I googled about this stuff.
Old 12-11-2008
DillonT's Avatar
is it bad to do on a truck with 140k miles? i heard it will clean too much carbon and leaks will show up.
Old 12-11-2008
TheBearJeweler's Avatar
nice.... getting mine tomorrow to do this weekend. my truck knocks like hell (octane ping)
Old 12-11-2008
get 3 bottles and oil jewler...
my truck has 168,600 miles on it and i didnt have a problem
Old 12-12-2008
CBFranger's Avatar
Post S/C vac?
Quick Reply: Motorcraft > Seafoam
