What lift for 35's?
What lift for 35's?
I am planning on lifting my truck and I have come across a smokin' deal on Hercules Terra-Trac A/T's sized at 35x12.50R15LT. I've got a 1993 4.0L Ext. Cab 4x4, which at the moment is bone stock. I already have a my eyes on a 4" lift from Rough Country, but the problem is I know that won't be enough with such a tall tire. A BL is needed I'm sure, but, I am also going to be installing 4" flared fenders and bedsides from Camburg.
What more will I have to do to run these tires?
Thanks in advance
Thanks in advance
He is running 8" skyjacker lift and 3" body. On 35x12.5x15 BFG M/T's.
2009_0208Image0001.jpg?t=1234116133
2009_0208Image0003.jpg?t=1234116152
2009_0208Image0011.jpg?t=1234116167
2009_0208Image0007.jpg?t=1234116182
If your going with the glass fenders then a 4" suspension and 3" body would be fine.
https://www.ranger-forums.com/forum2...erglass+35%27s
diffrent generation so it doesnt really count....but oh well
You can do a 4" suspension, 3" body and fit 35's on those generation trucks. I've seen it.
BUT....
Since you CAN get a 6" lift for it...spend the extra $100 and bump your lift to 6". you MIGHT be able to squeeze 35's in there...but i'd throw a 3" body ontop of that 6" suspension and rock 35's.
Here's maurice's 97 on a 6" and 3"...
BUT....
'rather than crawl in the mud'. who crawls in the mud and doesn't crawl on trails??
anywho...
remember...larger tires add to turning radius...so you might be going full lock after tires when before you wouldn't be at full lock for the same turning radius. There's a thread here that's active involing lifted 93-97 rangers..maybe look there for ideas. I'm not positive how clear you'd be with only 4+3, but i know i've seen it on the street.
EDIT: Post Your Gen III Picks (93-97)
anywho...
sure it might not fit your style or trent's....but it's a very nice unique truck that was just gorgeous. I almost bought it and drove it cross county to drive it home.
I think 35's are a bit much now that I've had time to sleep on it and discuss it with my uncle. As he so elegantly put it: "It's a damn MINI-TRUCK, if you want to go big, buy yourself a full-size."
So, I'm back to where I started; 4" suspension, 1-2" BL, and some 33's. And since Terra-Trac's don't come in 33's, I am considering MTR's
your uncle sounds like my dad... and ultimately its up to yourself...
i would rather drive a beefed up ranger with 33s or 35s than a stock fullsize truck... it all depends what YOU want! my girlfriend always tells me my truck is small and "cute" but what she doesnt know is how rugged them little rangers can be fullsize is nice but ill always be a ranger fan! anyways good luck with watever route you choose! im sure it will look awesome when its done!!
