8-Cylinder Tech If you are one of the few with a V8 engine in your Ranger, or if you dream of a Ranger with a V8 engine, this is the sub-forum for you.
Rat Ranger Build
Old 03-25-2009
94Ranger355's Avatar
Post Rat Ranger Build
Official notice of what I talked bout at the Ranger Meet in Knoxville!
This is gonna be my version of a Rat Rod and I doubt it's what they (the Rat Rod crowd) will be expectin:
Startin with this, less engine, trans, wheels & tires:
Picked up a 2" fiberglass bolt-on hood cheap:
Unloaded after 4 months on the trailer & cleaned up for first time:
And of course the RAT:
Would like to have it ready for the late summer Cruise-Ins and possibly the Oct. meet, but with my hours bein cut at work, kinda slowed thoughts/progress of the build, so may be next year before yuns see it out!
Will post updates as I go along, within reason................
AND to all you diehard blue oval folks: I don't wanta hear any negative crap bout Chevy in a Ford, as most know, I've done it before, and if ya don't like it, don't read/view/comment on it!
Old 03-25-2009
jckb4000's Avatar
sick !
That's gonna be able to lay some scratch!
Old 03-25-2009
GaryC's Avatar
its cool, your oval wears a bowtie....classy hahaha
Old 03-25-2009
Shaklakan's Avatar
Cool hwip!
Old 03-25-2009
wydopnthrtl's Avatar
Awsome.. I'm a big fan of true rat rods. I just don't like some of the weirdos behind them. Personally I like a more refined hot rod. But.. one that you wouldn't be afraid to drive anywhere, anyplace, anytime.
I can see by the cowl hood.. your not a true RR knuckle dragger. Just a regular knuckle dragger.
btw, if you pull that body off.. are you going to box the frame? Seems like a standard ranger frame wouldn't be strong engough for some serious twisting?
Old 03-25-2009
dlibson's Avatar
No problems with the frame. Pretty much anything a 350 can throw at it will hold together still...
Old 04-08-2009
Icon14 UPDATE 4-8-09
Well, been tinkerin with the RatRanger..............
Modified the radiator support for easier access:
Removed the bed for ease of access, tossed the PITA fuel tank, removed the rear suspension to include brackets:
And installed my NEW Explorer front spring mounts:
More to come>>>>>
Old 04-12-2009
Icon2 Update 4-11-09
Was a busy-beaver today:
Rear suspension mod done with the exception of weldin the spring perches once I get the pinion angle set & get my new shackles......
Rear crossmember removed, notched rear frame horns, installed 2X4 tubin to rigid it up, made shackle mounts out of black pipe that fit some bushings I found and mounted them to some 1/4" angle iron:
BUKOO room for Pro Street tires now:
Done for now:
Old 04-12-2009
Icon2 Update 4-12-09
Installed my shackles today:
SURVEY SAYS: WHOLOTTA ROOM for more tire inside the wheelwell:Name:  TireroomavailableonRatRangersetu-1.jpg
But as most know with mods, things don't always go your way.......for my setup, I'm gonna have to fab up some shock mounts, as I can't use the original ones as expected....no biggy, AIN'T THE FIRST TIME!
Old 04-12-2009
lookin good so far
Old 04-12-2009
Great progress. Can't wait to see some full truck pics.
Old 04-14-2009
Icon2 Update 4-14-09
Went with longer shackles to level it up some, frame is 19" from ground:
Made some shock mounts (1/4" flat stock & piece left from 2X4 rectangular tubin cut in half), haven't decided whether I'm gonna weld em on or bolt em:
GLAD you guys like it, looked good on paper & thought, and so far, all has gone as planned with a couple issues that were easily resolved.
Old 04-14-2009
there is a rat in your garage
Old 04-14-2009
Gallo75's Avatar
LMAO!!!
Old 04-16-2009
v-8 power's Avatar
Looking good. I bet you'll be able to spin whatever size tire you put on pretty easy.
Old 04-21-2009
DillonT's Avatar
looks awsome keep it up
Old 04-21-2009
Icon2 Update 4-21-09
Shock mounts installed........had to modify crossmember above the rearend to strengthen it for the shocks to mount to it:
Only thing left now is to weld up the spring perches after I set the pinion angle.....................
Old 05-01-2009
302project's Avatar
looking good bro
I like what u did with the leaf springs very nice
keep us updated!!
Old 05-01-2009
FRXLT's Avatar
Are you staying with the 7.5 axle?
Old 05-01-2009
Icon2 ????
Ain't no 7.5 under my truck(s), green one has a 8.8 outta 98 Explorer, the Rat Ranger has a 8.8 outta 92 Explorer, and may be tradin for a 8.8 outta 2000 Explorer this weekend...........
Old 05-02-2009
slammer67's Avatar
dude, that's awesome.
What's the specs on the big block?
I say tub it, it would look seriously cool
Old 05-02-2009
Icon2 Update 5-2-09
Got my gauge panel made finally:
Also made my switch panel:
ALSO picked up this 2001 Ranger steerin rack ($45 at salvage yard in Knoxville) with intentions of puttin it in place of the steerin box:
Nobody claims to have done it, so I reckon this lil' 94 will be the guinea pig
Old 05-02-2009
Ray_Welder's Avatar
How will you benefit from changing over to a rack from a gearbox?
Old 05-02-2009
I'm keeping an eye on this... I'm anxcious to see the results
Old 05-02-2009
Icon10 >>>>>
CLEARANCE! Big blocks take up alotta room.....
Quick Reply: Rat Ranger Build
