do I have an I-beam suspension?
someone asked me this and I wasn't sure: do I have an I-beam suspension on my '91 ranger, 4x1, auto?
I did a quick google to figure out that:
-an I-beam suspension is a simple design used to increase the capacity of heavy loads.
(picture c/o procarcare.com in autozone's auto library)
it's been almost exclusively used in ford's
in wikipedia, the I-beam suspension wasn't replaced until the 4th generation rangers (1998-present), so I'm guessing on that criteria alone, I DO have an I-beam suspension:
yes, I know I have a brake line leak...that's what this picture was originally taken for
so is my research accurate? is that what I have?
Originally Posted by Morph
The first picture you posted looks like a rear axle out of an older car/van. Just a drag-axle, not the 'I-beam' that the rangers have/had.
He was just confirming what you said.
yes you have an I beam front end......it is called a TIB (Twin I Beam) suspension......that was used in 2wd Rangers from mid 1982 all the way up through 1997 model year Rangers.......
the 4wd Rangers from 1983 to 1997 had the TTB (Twin Traction Beam) front suspension........
Both suspensions have a center pivot point. This was Ford's 1st real attemp at a IFS (Independent Front Suspension). This suspensions was not the best on the road since the motion of the axle caused tires to wear faster and allignments to be needed more often.
here is some info on the TTB style suspension
http://www.therangerstation.com/Maga.../TTBTuning.htm
HouseofFinch
09-11-2022 04:13 PM
Ranger093
01-03-2011 02:51 AM
