3rd Brake Light Turn signal
Old Oct 14, 2005
is there any way to make the cargo lights on the XLT turn on with the turn signals? i think that would be pretty cool to do...
would i have to change out the bulbs to amber?....
Old Oct 14, 2005
It's easy enough and has been done many times. Some people leave them white. Some use an all-red lens. Wowak has his set up to flash yellow - I don't know the details of how he did it but you could shoot him a PM.
Old Oct 14, 2005
Yea....I've got 'em. I've got a vid & instructions if ya want them. Just hit me up a pm, I'll email you them.
Old Oct 14, 2005
Wowak's Avatar
If you use the white lense you need an amber bulb to be legal. I use an amber bulb and painted the clear part yellow with glass paint so it would match my 98-99 style taillights.
All you have to do is locate the appropriate wires in the dash harness near the front of the transmission tunnel (use the front turn signal wires if you're using yellow bulbs, tap into the rear turnsignal wires if you're using an all-red housing, that way all three bulbs will light up when you hit the brake,) T into those wires, and run new wire up to the 3rd light housing (usually easiest to go under the door sill, up the inside of the B pillar {C pillar on a 4 door} and inside the headliner along the back) cut off the "hot" wire to the cargo lights, tape it off well so it never shorts to ground, leave the black ground wires connected, and connect the new wires to the appropriate bulbs.
I can't remember off the top of my head what the color codes are for every truck, but at least from 2000-2003 the front turn signals are green with a white stripe for the passenger side, and white with a blue stripe for the driver's side. If you want to use the rears, an easy way to find the wire color is to pop your taillight off and look what color the wire going to it is.
Old Oct 15, 2005
GrafixGuy's Avatar
I'd like to do it, I got the all red brake light
Old Oct 15, 2005
soccerjohn's Avatar
Check your state laws about the color. Here in KS its legal to use white, yellow and red.
Old Oct 17, 2005
Wowak's Avatar
Wow, thats news to me. White turn signal being legal? *shrug*
Old Oct 17, 2005
Rddvl23's Avatar
i have the red cover, but there would i get the other 2 bulbs and the holders from?
Old Oct 17, 2005
Wowak's Avatar
Autozone/Pep-Boys/Advance-Discount. Less than $10 total in parts. Just take your 3rd brakelight housing into the store with you and try some bulb holders until you find one that fits nice, and then get bulbs to fit it. Or if you frequent the junkyards, grab some out of an older Ranger w/ the bedlights.
buggman
42
Nov 21, 2012 10:39 PM
Mazdurr
Oct 7, 2011 06:43 PM
larz
Dec 30, 2007 12:00 AM
Hawklore
Sep 14, 2007 03:57 PM
Buttercup
27
Jun 19, 2005 07:37 AM
