bench seat swap in 1998 rangers?
Old Jun 19, 2008
Trucker_Eric's Avatar
Icon4 bench seat swap in 1998 rangers?
is it at all possible to take out the split bench and swap in a full bench seat?
Old Jun 19, 2008
Johns777's Avatar
Yeah if you make custom brackets it can be done. I have a full bench in my 2003. In the pic it is not bolted down yet.
Old Jun 19, 2008
What bench would fit? S10? Tacoma? Minivan? I'm curious.
Old Jun 20, 2008
i want to use an old bench from an older ranger that came with it.
Old Jun 20, 2008
Johns777's Avatar
Mine is out of a minivan. A ranger bench will fit no doubt and an s10 will most likely fit as well.
You prolly dont need custom brackets if your bench is from a ranger. If the years are close it might be a direct swap.
Old Jun 20, 2008
i want just a regular bench with only lap belts, i think its legal as long as theyre there, and then do custom 4 point belts, maybe 5 point, not sure yet, but i was looking at some, mine has a split bench with fold down console, i want just 1 piece for thye bech, non reclining, basic.
Old Jun 20, 2008
Johns777's Avatar
I know in my year ranger the seat belts have a sensor on the end and if not used can throw an engine code. Lap belts should work as long as its plugged in to the old seat belt part. As fas as a harness you will need to do a little more work but its doable some people on the site are running them. A harness with a bench seat I dont know about that.
Mine came out of a mini van and tilts forward for storage behind it which is nice. I keep recovery gear back there.
I would just remove the old bench seat and start comparing brackets and see if it is a direct swap. Then put lap belts in and be done until you figure out the harness situation.
Old Jun 20, 2008
well, i can run the 5 point in it, i dont have seat belt sensors, previous owner discnnected it somehow, i think, but even when its not plugged in, the lite dont come on.
Old Jun 20, 2008
mossyoak1992's Avatar
dont you have an ext. cab why would you want a bench seat in that and the only way your going to but in a 5 point harness with an ext cab is probably a roll cage
Old Nov 21, 2008
well, i like the 5 point restraint, but i dont think im gonna do it after all. i just want a bench seat becuz they are more cozy
Old Apr 12, 2012
sportouree's Avatar
What make/model and year did that seat come from? It looks great!
I'm putting bench seats in my 318i, and a ranger seat is a perfect fit.
-Garrick
rngprerunner
19
Jul 9, 2020 07:11 AM
skateboard34
30
Oct 28, 2018 02:57 PM
firebirdude
Feb 17, 2016 01:43 AM
mcd58
Dec 3, 2011 01:45 PM
MXranger489
Apr 9, 2007 05:25 PM
