HVAC only works on high
well yesterday on the way to work i noticed that my HVAC only works when i have it turned up all the way, on the three lower settings it does nothing, but once i turn it up all the way its blows out air, i have never had this happen before, anyone know what it might be
thanks
thanks
Originally Posted by 9XLT8
is there a way i can check the blower motor resister?
The blower can still work on the switch's highest speed because it bypasses the resistor block completely in that mode.
This is not a Ranger resistor but it is typical of what they look like:
Originally Posted by rwenzing
Unplug the 4 wire plug to the resistor block (under the HVAC blower motor in front of the pass side firewall). Then measure resistance across any two pins of the block, not the connector. There should be finite, measurable resistance between any pair of pins. Try several combinations. If the resistance on any or all combinations is maxed out on your highest analog scale or reads OL on a DVM, the resistor block has an open circuit or circuits and it's no good.
By finite, I mean not approaching infinite. In other words, you should be able to find a range on your multimeter that gives a numerical value of the measured resistance other than close to zero or over scale (OL on a DVM).
This is just a final check you can make before you decide to purchase a new resistor block. I'm 95% sure that the resistance wire is broken inside yours - it is a common failure on this part.
So I guess that it's worth the $15 just to replace it then.Thanks for the lightning fast response.
Ok, I've got a weird one, must have been that trip to Jackson. :) My blower started to act up this morning. Low, Med Low and High are working just fine. Med High is not. When I have the fan speed *** on Med Hi it blows the same as Medium Low.
I'm looking at the wiring diagram and the rheostat is in series, goes through 3 resistors for low, 2 for med low and 1 for med high. If my resistor was bad I shouldn't be able to get low or med low at all. The circuit would be open.
That leaves two things. Short/open circuit on circuit 752 or the blower switch is bad. Anyone else have any suggestions for other things to check?
Originally Posted by FoMoCoStang
no you dont, i just found a site that sells them seperately.
what might this web site be, because i still need to fix mine i have just been to lazy to do it but with it getting cold and all i would like my heat to work on something other than HIGH
Online for about $12 + S&H from FordPartsCheap
I realize this is an old thread. I figured I would tell about my experience. My blower motor resistor failed. I could not un plug the reistor from the harness. It was rusted together. After I finally got it apart the pins were stuck in the harness. I figured I am screwed now. I was going to cut the connector off and just put individual connectors on. I went to the auto store to get the connectors I needed and found the connector that goes to the wiring harness just like the one my pins were stuck in. It was even called a ford truck blower motor resistor plug. Must be a common problem.
What I am trying to say is dont spend an hour trying to get the plug off when it will be screwed anyway. Resistor at ford dealer 18.02. wiring plug 10.00. Total 28.02. Now my fan works on all speeds. Thanks to all who have posted.
Thanks for posting about the replacement connector. It's good news because corroded terminals at that plug are fairly common. A dab of dielectric grease on each pin should help to keep it from recurring. Dielectric grease is also a good preventative maintenance step for the connectors of new trucks, too, especially those that will see road salt.
My fan only works on the lowest and highest settings so I replaced the blower motor resistor. It was so corroded I had to destroy the resistor in order to separate it from the connector. The pins from the resistor were stuck in the connector and I had to pull them out with needle nose pliers. I plugged in the new resistor and my fan still only works on the highest and lowest settings. Do I need to replace the connector? Is there a way to test the connector I have?
