shackles
Old May 7, 2006
04lvl2's Avatar
Well the stock shackles alot for some movement from front to back and a rear pivot point for your leaf springs. You can also use a chevy drop shackle which will give about an inch or better of lift becuase they are longer.
Old May 7, 2006
Red_Ak_Ranger's Avatar
When your chevy springs get compressed(aka they flatten) they need to become longer.
Imagine it this way. You have a ruler stick(foot long) made out of metal. You hold it in your two hands(hands on the ends) and you push the ruler so that it forms a half circle. Notice that your hands pushed in to make it into a half circle? Well, when weight is put onto your springs, which flattens them out) they become a little bit longer. The shackles are what allows this.
Aaron
Old May 7, 2006
Exactly right.
And if your question should be interpreted as: "what do LIFTING shackles do?" -- then the answer is they push one end of the spring further from the chassis, thus lifting the truck a little. You get about 1" of lift for every 2" of extra shackle length, in general.
Bazman2008Ranger
Mar 28, 2015 10:10 PM
Taylor
Nov 27, 2011 09:22 PM
TippnOver
Dec 22, 2004 04:40 AM
n3elz
53
Nov 27, 2004 03:52 PM
n3elz
Nov 3, 2004 12:03 PM
