Front reciever pics?
Old Mar 24, 2008
black-n-blue's Avatar
Does anyone have any pics of how they mounted their front reciever.. preferrably valence-less? if so would you please post them
p.s. i tried searching but it said i had to wait 30 seconds.. for a good 5 minutes so i gave up on it
Old Mar 24, 2008
gumby's Avatar
mounted with a welder
Old Mar 24, 2008
Old Mar 24, 2008
https://www.ranger-forums.com/forum2...ad.php?t=23993
thats my old 01 ranger with a bolt in reciever: hidden hitch part #5014
but I also had a 3inch bodylift
Old Mar 24, 2008
ahh cool cool.., i didn't know they actually sold them like that..the reason i'm wanting to do this is that my front crossmember is all bent up.. too bent up to even attach some factory tow hooks..
would anyone see a problem with just buying the receiver itself.. and then weld it in with some beef angle iron and some other supports?
Old Mar 24, 2008
slammer67's Avatar
mine's built into the bumper
Old Mar 24, 2008
Just make your own man outta sq tube and drill a hole for a pin for say a winch or d-ring... mount it to the frame with some bolts then weld it up if you really want some strength...
Old Mar 24, 2008
Old Black Cat's Avatar
heres mine i scrached built.
https://www.ranger-forums.com/forum2...ad.php?t=50755
all pics there^^^^^
Old Mar 26, 2008
brianjwilson's Avatar
Bought a generic full size ford hitch and had it cut down, brackets welded back on and drilled to bolt to the tow hook holes.
Works great. Now my license plate is mounted to a receiver cover, and locked in there so you can't even tell there is a receiver until the license plate is taken out. Used a winch on it a couple times so far.
Old Jan 4, 2009
ShadowRanger08's Avatar
Originally Posted by jtslmn720
is it safe to cut that to fit the hitch in there? if so thatsd definately what ill be doing haha
Old Jan 4, 2009
Sure it's perfectly safe.....it's likely you are using the front hitch for recovery instead of the factory tow hooks. SO...it's completely safe to cut that crossmember. REALLY......2wd's dont even have that crossmember...it's there for merely mounting ofthe factory tow hooks.
Here's my hitch that's mounted above the frame instead of below....so the hole for the hitch will stick through the whole in the bumper on a bodylifted truck...
note...i welded the crossmember to the hitch for extra strength should somebody hook onto the tow hooks for some reason....(work in progress pic)
Old Jan 4, 2009
Rangerkid's Avatar
Shane, If I drive to Oregon your gonna help me install a hitch like this right?
Old Jan 5, 2009
Crunchy's Avatar
https://www.ranger-forums.com/forum2...ighlight=front
Old Jan 5, 2009
i have a 2wd and i have that crossmember...is that just another lovely luxury of the edge/sport?
and thats good to know i can cut that, now im not limited to how i mount my hitch on the front :)
Old Jan 5, 2009
buckgnarly's Avatar
I had no front xmember for over 5 yrs and 80k......all started with a bumper, ended with a receiver welded between frame rails.
Old Jan 5, 2009
Here she is done....it might look like i need to trim my valence up top, but it's just an optical illusion...
Old Jan 5, 2009
very nice Fx4wannabe01, looks like you did a lot of painting while you were at it, the truck looks new...just with a dirty body. I gotta find someone with a welder, theres so much i want to do haha
Old Jan 5, 2009
yea...i went to town with 1 can of John Deere Blitz Black. the illest color and paint ever.
Old Jan 6, 2009
that look real good shane. good work!
Old Jan 7, 2009
outdoorsman's Avatar
All put together.
Nice and Painted
In use.
Here you can see my buddy (Dusty08) and his DSG 08'. He has the Curt hitch mounted on the front.
Yessick
Jul 17, 2008 08:57 PM
99ranger4x4
Dec 29, 2006 06:39 PM
otterboy_99
Oct 4, 2006 11:36 AM
fletch12518
Audio & Video Tech
Nov 27, 2005 09:09 PM
optikal illushun
20
Jul 21, 2005 11:59 AM
