How do you carry/mount your Hi-lift?
Old May 28, 2006
got-dirty's Avatar
Im looking at some ways to mount it to my truck so its always there when i need it. I was thinking across the bed floor at the tailgate bolted to the bedfloor. I thought about the sides but i dont know how well the bed would liek the weight.
For the time being, till i find another job, i cant really go and buy the kit that they sell for jeeps and such. so im doing this with the basic bolts and materials i have at home.
Any ideas?
Old May 28, 2006
telemaster1952's Avatar
i plan to mount it on the inside of the bed behind the toolbox......or you could put it on the roof basket, on the bumpers, on the hood. people put them everywhere
Old May 28, 2006
got-dirty's Avatar
anyone else have ranger specific installs?
Old May 28, 2006
if i had one id make some type of studs mounted on the bed comin up it slid in then get some type of ratched to hold it down..IF I HAD ONE (:
Old May 28, 2006
got-dirty's Avatar
thats kinda what i was thinkin of. running 2 maybe 3 bolts fromt he under side of the bed up threw the floor. then sliding the jack down onto them and throwing some type of nuts on them but be able to lock them somehow, so the jack doesnt grow legs.
Old May 28, 2006
johnson's Avatar
get hi lift mounts from 4 wheel parts and mount them under the bed rail on either side... htey look like this from the side.. they are like 24 bux
Old May 28, 2006
johnson's Avatar
oops thats got messed up they are called 4xrac i think...
Old May 28, 2006
KARPE's Avatar
mount it on your hood right up under the windsheild it will make you look like a bad ***
Old May 28, 2006
i wanna mount one to my rolbar, saw an older ranger have it like that, while a spare tire carrier in the middle
Old May 28, 2006
Red_Ak_Ranger's Avatar
your rollbar is mounted only on the bedrails right? Or does it mount to the bed also. Cause i dont think a bedrails one would be good for supporting extra weight.
Aaron
Old May 28, 2006
What is the 'Hi-lift' ya'll are talking about? Pics.?
Old May 28, 2006
EdGe_wannabe's Avatar
Mount that junk to the hood! HA HA Just teasing w. ya man!
Brenton
Old May 28, 2006
got-dirty's Avatar
Old May 28, 2006
got-dirty's Avatar
another reason for wanting it at the tailgate, is more weight to the notoriously light ranger rear end. its an extra 40-50lbs.
Old May 28, 2006
this is hi lift.
Ironic i found a good pic of it mounted on a stepside ranger!
Aaron
Old May 28, 2006
Aaron
mines a factory stx bar that's inside the bed. the ranger i saw with the mount was a stx with the same factory bar
Old May 28, 2006
Sweet. I guess i'd like my spare at the end of the bed though, just because better weight balance on the back end and lower COG.
Plus I want my rollbar to have a good change in a rollover :-) which mine will.
Aaron
Old May 28, 2006
got-dirty's Avatar
this is hi lift.
Aaron
saw that already, truck has a full Fabtech suspension as well.
but i dont have a stepside.
Next idea .....
I use mine often, so it needs to be with me and readily availible. I used to carry in the cab behind the seats, but now i cant with my sub box.
Old May 28, 2006
KARPE's Avatar
I still say on the hood
Old May 28, 2006
Make some kind of a hanger for it and attach it right under the bed rail. If you have a bed liner this could be a problem.
Old May 28, 2006
First, that's what jeeps do. And it's because its much easier to attach there. Second, a jeeper would always have to remove the hilift to open the hood. Since it folds up to the window so close i think you would have to.
Aaron
Old May 29, 2006
Old May 29, 2006
Thumper102's Avatar
Old May 29, 2006
Ya that's exactaly what I was talking about!
Old May 29, 2006
you better figure some way to lock it down heh. Or it just might walk away.
Aaron
