backspacing
Old Feb 16, 2006
thirdfrank's Avatar
backspacing
i just bought some 16x8 rims with 5'' backspacing. i also have 33x12.5 tires. do you think the backspacing will create a problem?
Old Feb 16, 2006
CanadianXLT's Avatar
dunno what kind of ranger you have but 5" is quite alot of BS. I beleive stock BS is 4.5". I guess your wheel will stick in more and create more chances of rubbing.
Old Feb 16, 2006
oh and I hope you have some sort of lift to fit them 33*12.5
Old Feb 16, 2006
thirdfrank's Avatar
I have 2002 edge 2wd and im putting a 3'' spindle lift and craking the t-bars
Old Feb 16, 2006
034x4's Avatar
holy ****, the stock wheels have 4.5" of backspacing! 5" is way too much, especially with 12.50 tires they are going to rub like a sumbihc!
Old Feb 16, 2006
8" wheels with 5" backspacing have exactly the same +12mm offset as factory 7" wheels with 4.5" BS. 33x12.5's with those wheels are going to rub like hell on the inside, even with a lift.
Old Feb 16, 2006
thirdfrank's Avatar
DAM!! well i already purchased them and was told that it would be fine by someone. well now that i have it. what could i do to prevent so much rubbing??
Old Feb 16, 2006
spacers.. but meh id try to return them and get others
Old Feb 16, 2006
thirdfrank's Avatar
These are what i got. am i reading it wrong? I noticed alot of them are that size..
http://www.americanracing.com/wheels...lloy&section=S
Old Feb 16, 2006
Old Feb 16, 2006
thirdfrank's Avatar
Thanks Billy...............
Old Feb 16, 2006
Chucks05EDGE's Avatar
Incorrect guess!
5" backspacing will bring the wheel .5" closer to the truck. 4.0" backspacing will put the wheel out from the truck by .5"...
With the 16X8, you should have gotten a 4" backspacing, to compensate for the extra half inch of wheel width on the inside...
Old Feb 16, 2006
lol what do you mean incorect guess? I said his wheel will stick IN more no stick OUT... and stock is 4.5...
Old Feb 16, 2006
thirdfrank's Avatar
Ok well i cant do anything now. is there a certain solution to handle this,besides returning them? i cant do that....
Old Feb 16, 2006
buy spacers like I said above.. but yeah youd have to get like a 1" wheel spacer.. dunno if they make em that big. Either that or sell them and get some new ones.
Old Feb 16, 2006
thirdfrank's Avatar
OK cool, i guess thats what im going to have to do. how big are they?
Old Feb 16, 2006
Heres a link to give you an idea of what they are.. and ya I guess they do make some 1" and more.. http://www.rockcrawler.com/techrepor...cers/index.asp
Old Feb 16, 2006
thirdfrank's Avatar
OK thanks. wow its more expensive then i thought.......
Old Feb 16, 2006
OOPS!!! All I saw was stick and I ASSUMED it was stick out!
Who says stick in anyway? lol
I know stock backspacing is 4.5", re-read my post then...
He got 5" backspacing, and you are suggesting a 1" spacer....
I said he should have gotten 4" backspacing, which is the same thing, only safer than using a 1" spacer...
Old Feb 16, 2006
Pinecone's Avatar
I'll just say, I don't think its recommended you use spacers if you are gonna offroad, just try selling the rims and get one's with 4" BS or 3.5" BS.
Old Feb 16, 2006
thirdfrank's Avatar
im not going offroading. its just for looks. i just bought the rims two days ago.
Old Feb 16, 2006
Pinecone's Avatar
I don't know, I still wouldn't trust spacers with that size tire and rim.
Old Feb 16, 2006
thirdfrank's Avatar
well i really dont have a choice at this point cause i would just loose a lot of money if i sold them. Im just gonna try. I have a buddy who did spacers and got really big washers and he said he didnt have a problem.
Old Feb 16, 2006
fx4me's Avatar
Where did you get them? Check their return policy, maybe you can refund or exchange them.
Old Feb 16, 2006
thirdfrank's Avatar
well i dont have them . my friend got a hook up from this manager at a tire place so the used tires already got put on them. I dont think they would return them. They are are also two hours away from me
