About to seafoam, wheres brake booster line?
Old Mar 3, 2008
yellow rhino's Avatar
I'm not exactly sure which is the brake booster line. I have my guess but I want to know for sure before i do it. I'v searched but only found descriptions. Does anyone have a pic of it? Thanks
Old Mar 3, 2008
Danny818's Avatar
different year ranger but should help....
http://www.rangerpowersports.com/for...e+booster+line
Old Mar 3, 2008
its the only line coming off the big round thing(booster) attached to the master cylinder. It runs from the booster to the intake.
Old Mar 3, 2008
Old Mar 3, 2008
SparkYZ's Avatar
Jared how many miles are on your truck? Seems a bit new to be seafoaming..
Old Mar 3, 2008
schatten789's Avatar
Well others have already answered your question but I just took the time to circle it in a pic, so im going to post the pic anyway. lol
Old Mar 3, 2008
Got it done woot woot. More smoke came out than expected but i guess it's a good thing that I went through with it. Idle is alot smoother and quieter and thats all I'v noticed so far. Hopefully tommorow I'll notice some big improvements goin do the freeway.
Old Mar 3, 2008
I never get smoke
I have done it in 4 vehicles to.....
Old Mar 3, 2008
01 ranger 4x4's Avatar
what is a good amount of milage to have before doing this? I have 60k mi on my 4.0 and it has hard starts bad gas milage and a rough idle
Old Mar 3, 2008
Lord Of War's Avatar
I dont think there is a certain mileage that needs to be hit before you can use seafoam. The only caution that I have heard is that using it on engines with a **** load of miles can cause problems.
Old Mar 3, 2008
I would Seafoam A.S.A.P.
Old Mar 3, 2008
I need to do some Seafoam, but i gotta wait until the next oil change.
Old Mar 4, 2008
i thought if ou put the seafoam in the brake booster line you dont have to do an oil change only if you put it directly in the oil. am i right?
Old Mar 4, 2008
67cobain94's Avatar
I used it through the booster and if you let it sit the five minutes after it ran at temperature it will smoke pretty well if you rev it up some. I didn't change my oil either. I use Marvel Mystery oil as an additive to the synthetic instead.
Old Mar 4, 2008
so some people put 1/2 the bottle in the brake booster and others put it in the gas and others put it in the oil. Can i put 1/2 in the brake booster the other 1/2 in the gas (at the same time) and not have to change the oil?
Old Mar 4, 2008
TommyC's Avatar
Okay seems a lot of people don't understand Seafoam at all. For starters, there are instructions on the bottle, read them.
There's three injections methods for Seafoam, and they all do different things. You can put it in the gas, oil, or brake booster.
1) Gas - Cleans fuel injectors, fuel lines, removes moisture from fuel lines. May require changing the fuel filter sooner as the filter catches the junk.
2) Oil - Cleans out the buildup in your oil crankcase. Requires changing the oil filter soon after.
3) Vacuum (Brake Booster) - Cleans intake valves, cylinder, top of the piston, exhaust valves, etc. This is the most common method, and is the one which causes excessive smoking. May require changing the spark plugs sooner.
Old Mar 4, 2008
What Tommy said.
Very well put
Old Mar 4, 2008
alright thanks for the info but can i do two methods at the same time
Old Mar 5, 2008
Prerunner-Ranger's Avatar
Level I Supporter
What if I just changed the spark plugs about 1,000 miles ago and I run seafoam? I won't have to replace them again will I?
Old Mar 5, 2008
TommyC's Avatar
I've read that Seafoam only fouls the spark plugs if they are already in a bad condition to begin with, if that's true or not I have no idea. I wouldn't worry about it though. I know most people don't change their spark plugs after using Seafoam, and haven't really read any complaints.
If anything you may want to just pull out a spark plug and check it out afterwards, or change your spark plugs a little sooner than you would on your regular maintenance interval.
Or heck, if for some weird reason you saved your old spark plugs, re-install them, seafoam, and put back the new ones.
Old Mar 5, 2008
Level I Supporter
Lol, thanks TommyC.
Old Mar 6, 2008
Level I Supporter
Just sea foamed my rig and it's running a lot better!
Thanks RF.
Old Sep 1, 2015
littleyellowstinger's Avatar
high mileage
Hello all,
I have a 2000 3.0 4x2 automatic ford ranger with over 230k miles. I am fairly sure it has never been seafoamed using the brake booster method. I use gumout, marvel mystery oil, seafoam and Lucas ethanol treatments in the gas tank all the time. Here's my question though I have never had a problem engine wise out of my truck in the three years that I've had it. The previous owner was a salesman and 210k plus miles are interstate miles. So my check engine light keeps coming on and it turns my 20mpg cool quick little truck into a slow chugging slug of a vehicle and drops me to about 13 per gallon... If I were to seafoam the truck using the brake booster method, would it clean up the carbon deposits that are causing my sensors to misbehave? Or would it mess up my truck? Again I put cleaners and solvents in the tank every 2-3 weeks and I use only premium gas. And advice would be helpful I just want my little buddy to have some pep in his step and get better gas mileage.
Old Sep 1, 2015
RLong31's Avatar
The Ban Hammer
It shouldn't do any damage. I usually do it in the booster line right and a little in the oil right before an oil change. That way all the crap it cleans out goes out with the dirty oil. Just expect it to smoke.. a LOT. Read the directions and you will be fine.
Old Sep 1, 2015
Thank you sir!! I will be doing this tomorrow afternoon
