Suspension Tech General discussion of suspension for the Ford Ranger.
Explorer 31 spline SOA help.
Old Aug 14, 2006
Ranger1's Avatar
I managed to get the spring perches but I can't seem to find the new shock mounts or upper spring plate(the piece the U-bolts go through).
Old Aug 14, 2006
i just made some brackets..well im gunna make some brackets i havent gotten that far
Old Aug 14, 2006
SuperGildo@RRP's Avatar
why dont you just set it up like the ranger and wheld shock tabs on the axles...
Old Aug 14, 2006
Ranger1's Avatar
Thats the plan. I was looking for some pre-made readily available universal shock mounting tabs that could be welded to the axle. Kind of like how I am just buying the spring perches and welding them to the axle i wanted to do the same for the shock mounts.
Old Aug 14, 2006
Ranger1's Avatar
My axle is currently with the guy installing the gears. Anyone know the diamater of the axle housing ?
Old Aug 14, 2006
sawred's Avatar
You mean this?
OK4WD. Search "Shock Mount"
Old Aug 14, 2006
Ranger1's Avatar
Originally Posted by sawred
yeah that looks like it will work.
Old Aug 14, 2006
Ranger1's Avatar
also I need a set of U-bolts, I thought I had some that would work but they aren't big enough. Any suggestions ?
and they all else I need is the top spring mount/plate
Old Aug 14, 2006
V8 Level II's Avatar
These guys have all kinds of prefab brackets including dozens of shock mounts.
http://www.aa-mfg.com/
Most of their stuff is stamped mild steel but some items are available laser cut and/or 4130. The prices are decent and shipping is prompt. You can order online or by phone and they'll send you a free paper catalog, too, if you want.
Old Aug 14, 2006
Ranger1's Avatar
Would this work
http://www.ok4wd.com/index.php/catal...tallation_kit/
Old Aug 14, 2006
The Explorer axle is larger than your Ranger's. You can get u-bolts for an early 90's F150 or a Level II and they will be the right spacing, you would just need to get the correct length. Level II u-bolts would be exactly the right size if you are running the factory blocks only.
Since Level II's have the same diameter axle tubes as a 2001-back Ex, the LII spring plates will fit perfectly.
Old Aug 15, 2006
Ranger1's Avatar
I ended up ordering perches and shock mounts made by performance accessories(same company as my body lift)
I ordered them from this site.
http://accessory-center.com/default....cessory-Center
For the U-bolts I ended up ordering a set of lift blocks with U-bolts for an F150. I shouldn't need the blocks for any reason but for the price it works. Since they are made to work with the lift bolts they should be more then long enough.
U-bolts, perches, and shock mounts came to about $90.
I still need the upper spring plate but i think I will either buy it new from ford or buy a junkyard piece. I guess if I had to i could fab them.
Old Aug 15, 2006
Ranger1's Avatar
I got the upper plates from
https://broncograveyard.com/
$40
Old Aug 15, 2006
Ranger1's Avatar
I kind of thought more people had done the 31-spline explorer swap.
Old Aug 15, 2006
A lot more low riders do the Ex swap because it is closer to a bolt on as a "spring under" installation. Lots of them on RPS.
Old Aug 15, 2006
Ranger1's Avatar
Oh that's interesting. I still kind of thought a lot of people put the 31 spline units in lifted trucks for strength.
Old Aug 15, 2006
Some have done the EX swap to SOA trucks but, as you know, it is not a bolt-on mod. This takes it beyond the capabilities and/or resources of many owners. Also, the Level II's already have 31-spline axles, so they don't need to be changed.
Old Aug 15, 2006
Ranger1's Avatar
Oh yeah I bet the LII is a more popular swap. Oh well the axle was super cheap. I bet i still came out a head for the cost of a LII axle.
Old Aug 16, 2006
alot of the guys on TRS, just weld up their own stuff, and dont have to buy anything
Old Aug 17, 2006
sawred's Avatar
you could just leave it SUA and gain more uptravel... oh wait wrong coast
Old Mar 7, 2007
Hey what size spring perches do I need to order 1-3/4", 2", 2-1/2" or 3"? Also on the shock mount do I need to order the shock pins or would the ones that come with the shocks work?
Also I just ordered traction bars from James Duff will they work with the f-150 u-bolts and plates? I ordered the 31 spline James Duff mounting plates.
Thanks to anyone and sorry for all the questions
Old Mar 9, 2007
Ranger1's Avatar
I ordered the 2 1/2 but I think the 3 inch would have worked better. For the price if I was doing it again i would get both and use the one that works the best.
You do not need the shock Pin I got them but didn't need them.
Not sure about the trac bars. I think so but not 100%. I ordered stock Bronco/F150 spring plates, so I would think that would be good.
Old Mar 9, 2007
andy the duff bars should work its no different then the guys running them on their lvl2s
Old Mar 10, 2007
Cool thanks guys I am picking up the explorer rear end tommorow and hope to have it installed by next weekend with the traction bars
Old Mar 10, 2007
BigBlueEDGE03's Avatar
sounds awesome man. Hope it works for ya.
I was just asking my friend today about an explorer axle, with or without disc brakes. It'll be a little while before i do that though.
99fordranger
Drivetrain Tech
20
Oct 31, 2019 04:14 PM
MXranger489
Drivetrain Tech
17
Jan 25, 2010 06:54 PM
01xltranger4x4
Drivetrain Tech
25
May 18, 2007 12:09 PM
D94R
Drivetrain Tech
52
Mar 21, 2007 09:51 PM
jrpro130
Drivetrain Tech
16
Oct 9, 2006 09:42 AM
