$8.00 gap guards...
Old Oct 13, 2005
rangererv's Avatar
$8.00 gap guards...
Finally got around to MAKING my own gap guards.
When i read that they were $70 i said no way im buying them.
It was soo simple to make them i dont no why anyone wouldnt.....
I bought some rubber and made my own for just under $8.
and i think they turned out very good.
what do you think?
before
After
wraped around the back to stop mud
goes way up front to. ( the last screw was SOOO hard to put in. i couldnt see what i was doing)
no mo gap!!
Old Oct 13, 2005
olsonk_89's Avatar
Looks good. If I do a BL, I will definately do it that way. No sense in spending $70 for an $8 piece of rubber. Good work.
Old Oct 13, 2005
nice evan what you end up using
Old Oct 13, 2005
NHBubba_Revisited's Avatar
Is this a largely cosmetic thing? Or is there a functional need to 'guard' the gap?
Old Oct 13, 2005
JP03RFX4's Avatar
how did u attach them?
Old Oct 13, 2005
just cosmetics, since the bed is 3 inches off the frame.
looks good evan
Old Oct 13, 2005
a311fanam's Avatar
looks good
Old Oct 13, 2005
rangererv's Avatar
self taping screws
Old Oct 13, 2005
rangererv's Avatar
i was at aco (hardware store) and i found a piece of rubber that is made to cover stairs so i just reversed them. each piece was pre cut to fit 1 step. i used 4 of them
here is what it looked like on the other side.
Old Oct 13, 2005
Nicely done. Did you just screw them into the bed?
Old Oct 13, 2005
Morph's Avatar
Good Job. I'll be going this route when I do mine. Thanks for the headsup!
Old Oct 13, 2005
Mason's Avatar
Cool. 70 bucks is way to much thats why i didn't buy them either. I'll have to try makeing a set.
Old Oct 13, 2005
rangererv's Avatar
there is a little lip under the bed that i drilled into.
Old Oct 13, 2005
meemooer's Avatar
Looks good. Good thinking with the stair covers.
i just put mine on about two weeks ago. I came across a whole roll of that rubber that goes down the isle of a school bus, cut it in half[width wise] and drilled then put a bolt and a nut to keep them up there.
On the front, i ran mine like you did the back[as i did as well] I tucked it in the fender flare and re-used that plastic push pin. I could get the drill to stay in place to go forward you you did.
BTW what is that red wire going across by your fuel line? [3rd pic]
Old Oct 13, 2005
04lvl2's Avatar
That looks pretty good, I am next lol.
Old Oct 13, 2005
rangererv's Avatar
hey bill i will help you if you want.
just give me a call. very easy, but it took me a lot of time to get it perfect.
Old Oct 13, 2005
rangererv's Avatar
power line for my trailer hitch connection.
it goes to the battery
Old Oct 14, 2005
CanadianXLT's Avatar
looks good evan
Mainly comsmetic but I would say that in the front it would prevent the mud getting in the engine compartment..
Old Oct 14, 2005
And good job rangererv, looks good
Old Oct 14, 2005
rangererv's Avatar
thanks for all the comments guys
Old Dec 11, 2005
Jack Sparrow's Avatar
old post but....how is your front done?
Old Dec 11, 2005
04lvl2's Avatar
It is not done not is mine, just the factory ones are up front and it does not look bad.
Old Dec 11, 2005
got-dirty's Avatar
a bigger tire will cover it up. but im sure you can fab something up with that stuff to make a new one.
Old Dec 11, 2005
rangererv's Avatar
ya, there really is no need for front gap guards.
Old Dec 11, 2005
got-dirty's Avatar
aesthically maybe not. but the front ones do keep a bit of stuff out of the engine bay, and off your exhaust and such.
