Quick HELP NEEDED!!
Old 03-12-2006
got-dirty's Avatar
Quick HELP NEEDED!!
Whats the cure for this? And the operation to get a healthy truck again?
Old 03-12-2006
dont know much when it comes to this subject..
New U joints maybe i dunno
Old 03-12-2006
got-dirty's Avatar
anyone else?
Old 03-12-2006
blue_bandit's Avatar
hold on ill see if i can get you some help man that dosnt look good
Old 03-12-2006
think the part thats messed up is the yok(like the stuff in a egg sorry cant spell) but dont quote me sorry i cant be more help my friends got a haynes book but hes not home
Old 03-12-2006
my friend said its a carrier bearing he is pretty sure thats what its called
Old 03-12-2006
wow ya something is messed up in the tail end of the trans i couldnt tell with out it off
Old 03-12-2006
got-dirty's Avatar
well i took the DS out, and took that piece off, and put the DS back in. My dad believes its some sort type of harmonic ballancer for the DS like you have for the crankshaft pulley.
I drove around the block, an di get a couple lil vibrations, lil buzz's, but thats about it. ill have to deal with it till i can get the new end.
thanks for the help.
Old 03-12-2006
Yes it is a balancer you do need it to not distroy the crap out of your trans
Old 03-12-2006
shadyluke's Avatar
I had the same thing happen. 300 some bucks bought me a brand new drive shaft. This was on my 98. The guy tried telling me it was from doing burnouts but the truck could barely chirp the tires with a 4 banger and 3.45 gears
Old 03-12-2006
got-dirty's Avatar
so that part is none repairible? I was kinda thinkin that, as it looks like its either pressed onto the yoke, or you have to replace that hole end.
I hope i can find a cheap driveshaft in the junkyard. will a newer model aluminum shaft fit? like ones from an edge?
Old 03-14-2006
got-dirty's Avatar
Just an update. I called the ford dealer, explained my problem and what i needed, they didnt have any in stock so they referred me to a driveshaft shop. Called them up, talked to the guy, and explained that the balancer is not needed. They remove the balancer from the brand new yokes they install, to prevent situations like mine. He said that if you reinstall the shaft, and have no vibrations, then it will be fine. If you get vibrations, bring in the driveshaft and theyll rebalance it.
OneTireFire
04-15-2010 06:34 AM
dmathews
11-15-2009 01:30 PM
BigRedDog
10-07-2009 06:10 PM
dantheman
05-16-2009 12:52 AM
Quick Reply: Quick HELP NEEDED!!
