Kill switch how-to?
Originally Posted by jrpro130
I want to do one with a push button, you push the button as you get out of the truck, push it back when you get in...this way it is a little less noticable.
You can always just cut the wire to the positive ignition and wire in a kill switch...right under the colum or something???
Originally Posted by bwester04
do you not have that start disabler thing down there boy the hood release? you just pull it and the truck wont start.
I'm thinking of having something in the cab. I leave my truck, flick the switch, and it won't start. I get up to go to work in the morning, flick it on, and off I go.
I just found this...
Is this complete?
kill switch man now.. find the roll over switch for the fuel cut off near the passanger's feet on the kick panel. take the kick panel off, there will be 2 wires running into it. cut them extend them to a hidden place, us a GOOD METAL switch HIDE IT, connect the wires...flip it for off truck will start for like 2 sec then die, runs out of fuel brother will probly freak out after that because he cant get it to start and think he broke it...life is good..
Here is what I was talking about:
Turn the key and push your truck and pop the clutch it will start. (if you have a stick anyway)
It works a lil better on an auto untill, the wires come uncrimped and your stuck wondering why your new truck wont start. Because some newbie ford tech used the yellow butt conector instead of the red conectors. Ive had that crap on two of the vehicles I bought from the local stealership. They charged me for it on the ranger, give me the paperwork and all for it. But they never installed it, and woulndt give me my money back. I got it back driving thru thier car wash every week for a year, untill they put a key code on it.
/endrant
When I bought my 03, I asked about having it installed, but nobody knew what I was talking about. Then they gave me the speech aboout the PAS key being already installed.....blah, blah, blah.
you can engage/disengage the inertia switch
just use your key and pop the plunger up thru the provide slot
then just push it back down when your ready to go
no mod needed
FYI the 4.0 doesnt run long after with no fuel pump, but a 2.3 will idle for 5 minutes
btw the fuel reset light will come on on the dash unless you mod that
no mod needed
Originally Posted by FireRanger
If you are going to use the fuel shutoff, do not just cut it out, totally disabling it. That switch is really important. Add the new switch in series so that the inertia switch can still function.
no mod needed
no mod needed
Kill the fuel, not the battery
This is exactly what I did when the inertia switch connection melted. It was either $50 for a new switch from the dealer or $5 for a toggle switch. Ran it to a hidden spot and BAM! Instant kill switch. Plus if you run a disconnect to the battery, wouldn't you lose all the preset info on your stereo every time you flipped the switch?
