PROBLEM: (ABS Light)(Brakes)(Steering)
Old Sep 11, 2006
Trevelyn1015's Avatar
Still El Presidente...
Here's what it's like to drive my truck right now.
You're driving down the road. ABS light is on. You hit the brakes, as you normally would, they are really soft - go all the way to the floor. You hit em hard, the pedal turns into a rock, and the whole truck steers to the right HARD AS IT CAN.
Pump the brakes, and they get hard, won't work.
Hit the brakes, normally, at any speed - no braking power.
Hit the brakes kinda hard, but not fast - some stopping power.
Slam on the brakes - steering turns you hard right. very hard right.
There is a constant squeek/metallic noise from the driver's side brakes/wheel.
Old Sep 11, 2006
SuperGildo@RRP's Avatar
um new brakes? bleed the lines? check ABS connections?
Old Sep 11, 2006
l2en's Avatar
On top of gil's suggestions, stuck caliper slide and fubar'd rotor on the dr side.
Old Sep 11, 2006
i would sssay your pad fell apart on the drivers side.
Old Sep 11, 2006
my truck would pull to the left when on braking..i put new pads on a few weeks ago..the left rotor was nasty..we had to turn it 3 times to get it all straight..so it wore funny on the pad..but everything is all good to go now..
Old Sep 11, 2006
shadyluke's Avatar
Wow and I thought mine were bad. Good luck getting this fixed so your not without the truck any longer
Old Sep 11, 2006
The rear drums on our trucks are a big pain in the but when rusty or mudded up. I have this type of thing a lot, though not quite the same symptoms. If you don't find anything up front, then take the drums off and check the rears. Particulary make sure that the adjusters work and that the rears are properly adjusted.
Also, that resistance problem sounds like it could be something in the brake booster. Going down too far is often the rear brakes being bad. High resistance and low stopping power is usually the master cylinder or booster.
Old Sep 11, 2006
If it's not one thing, it's always another thing, huh?
Gah.
Aftre 5 years, though, and 50,000 miles, I guess the brakes would naturally be going out, right?
I'm sure I've had the pads replaced and the rotors turned, a few years back...
Old Sep 11, 2006
Gah.
yeah i might say its about time. ive done my brakes like 4 times in 44k...
Old Sep 11, 2006
Well, you were all wrong.
My something bent and broke or...
Who knows? Probably the ball bearings or whatever or the spindle gave away.
It's about to be towed back to the mechanic, 60 miles away.
Bummer:
Old Sep 11, 2006
shadyluke's Avatar
ewww. Sorry for your luck man
Old Sep 11, 2006
l2en's Avatar
Damn man, sorry this had to happen. Hopefully it's nothing major and you're not out of a Ranger for too long....again.
Old Sep 11, 2006
oh wow, yea something broke.
Old Sep 11, 2006
why to a mechanic?!?!? tear that beetch apart and fix it yourself. unless its something really fawked like you snapped the upper a arm mounts off(extreme case), it should totally be something you could do yourself fairly easily...
Old Sep 11, 2006
damn man ouch wonder if the upper ball joint sayed F-you and let go
Old Sep 11, 2006
Cape Fear's Avatar
I was thinking that but it looks like the lower one. See how far the bottom of the wheel is pulled out compaired to the rear.
Old Sep 11, 2006
texasbullseye89's Avatar
my friends s10 looks like that on the passenger side. broken upper arm and arm mounts is his problem.
Old Sep 11, 2006
if:
a) i had tools at school
b) if my apt. complex would let me work on my truck in the parking lot
c) if i had the time to work on my truck
d) if i wanted to do it myself
Old Sep 11, 2006
mammioo's Avatar
christian graduates in may. he is taking 18 hours this semester.
i'm very proud of my boy.
we have good mechanics here in college station.
Old Sep 11, 2006
That sucks man! Let us know what it is. I love the looks of your truck, but I don't want your luck.
Old Sep 11, 2006
Im sure hes an angel, but im taking a lot of school too. Ive had to pull off the highway and do fixes in parking lots before. our front ends dont require that many tools/time. its pretty simple if you know youre goal.
Im not trying to say hes a bad guy, i think hes a good guy i was just suggesting. I guess im just always eager to save the expensive labor money of a mechanic and do things myself...
Old Sep 11, 2006
Christian are you in CS right now? Give me a call if you need some help man.
Old Sep 11, 2006
Bigwill41's Avatar
I think the Cooper tire did it... lol
That sucks Christan. I hope you get it rollin soon..
Old Sep 11, 2006
jrpro130's Avatar
Looks like lower ball joint. Mines going bad too. It's an easy fix though.
