Rough Jerk in Brakes or Transmission...
Old Oct 1, 2006
mar01Edge's Avatar
hey guys I'm knew to this site. I just bought a 2001 Ranger Edge so I can keep my Mustang stored in the Garage. .. ..
Anyways, my truck is having a rough jolt or jerk once I initially hit the gas after its been parked. Its hard to explain and this is my first truck so I don't know if it's normal because of the low gear ratio or what....
It also happens when I come to a complete stop and then go to hit the gas the truck feels like it jerks or jolts once or twice while shifting in then out of first gear but it shifts through the other gears just fine. It's only when I'm to a stop or pretty close to it. I don't know if it can be ABS related or there is something wrong with the gears or transmission.
I hope i explained that well enough and you guys can help me...Thanks a lot
Old Oct 1, 2006
This is a common complaint. The Ford fix is to grease the driveshaft slip yoke but it usally lasts for only 1~12 months before recurring. I fixed mine permanently by installing a set of traction bars.
Try a search on "slip yoke" or "slip bump" to find several threads and lots of info/opinions on this subject.
Old Oct 1, 2006
There's a rough jerk in my truck also...
...but he sits behind the wheel...
Old Oct 1, 2006
MonsterGuy's Avatar
mine had the same prob when i test drove my truck adn i brougt to a ford dealer and they doint know what was wrong with it it was just a quick inspection then i drove it to a transmition place and he fixed it for free for me when i bought the truck so i could talk the price down a lil for it :) but now i got my new traction bars and i never feel it now.
Old Oct 1, 2006
mar01Edge's Avatar
is this something to worry about or no? I don't know this to cause some serious damage. What's a good supplier for those traction bars and what exactly do they do to help? This is tranny related I take it?
Old Oct 1, 2006
FireRanger's Avatar
only time i ever notice something like that is if i step on the gas too soon after putting it in drive. If I go to 2 or 1 instead of D, it goes right in right away no matter how soon i step on the gas
Old Oct 1, 2006
MonsterGuy's Avatar
no its not ur tranny if u look on ur driveshaft going to ur rear diff ull see a black boot on it u can greese inside the boot and close it back up again and it should go away it is just lack of lupe on the slip shaft.
if u notice when u hit the gas ur trucks rear lowers and when u hit ur brakes the truck leans forward and the slip shaft is moving with it like a shock type of thing.
traction bars that i have are James Duff Traction bars u can go to there websight same as the name and the make it so ur rear axel can only move up and down and cant twist or move any other direction accept the way the axel is sposto move.
u cna also do what bob said to do and do a search for the topic they will have more info on it prob.
Old Oct 1, 2006
Here's a link:
http://www.jamesduff.com/broncoII/tracbar.html
Your 2001 uses:
#5304 '98+ Ranger Small Housing $89.00
Fairly easy to install. You need to drill 3 holes on each side in the forward spring hangers. The rest is bolt on.
Old Oct 4, 2006
mar01Edge's Avatar
hey thanks a lot. so these traction bars should fix this problem I'm having? are they easy to install or are they a pain in the a$$? pretty much these traction bars just keep the driveshaft and differential from sliding in different directions which make it jerk once i stop or hit the gas, they just keep my rear end more stable??? hey thanks a lot...and these tractions bars for $89 comes with all the other hardware required?
Old Oct 4, 2006
It cured mine and many others. If the issue is the slip yoke binding, these should fix it. They also reduce wheel hop greatly if you have that problem.
All hardware is included. Not hard to install if you are at all mechanically inclined. Like I said above, you have to drill 3 holes per side, the rest is bolt on.
Old Oct 9, 2006
xxtomorrowsliexx's Avatar
when coming to a stop and almost stopped or just starting my truck seems to bump a little bit....is this what you are referring to as your problems with the slip yoke?.....the best way i could explain it is 3 or 4 bumps...happens sometimes when stopping but more so when im just starting off slowly....if i hit the gas hard it kicks right in gear and takes off....if i ease onto the throttle this will occur with the bumps.....then it shifts fine in all gears....same problem as the slip yoke or does this sound different?
Old Oct 10, 2006
The Rangers I've driven do it just once on light-to-moderate initial acceleration or when decelerating and nearly stopped. It happens as the torque across the slip yoke changes and it jumps suddenly to a new position.
Old Oct 10, 2006
MonsterGuy's Avatar
i thumped between 3-4 depends how slow i did it. i say just take ur driveshaft out and and greese the inside of the boot and see if it goes away. you can do it yourseld or a garage can do quick then you will elliminate that problem with it.
Old Oct 10, 2006
mar01Edge's Avatar
yea that's exactly the problem xxtomorrowsliexx. I've heard that if I grease the slip yoke it will only be a temporary fix and to be honest I'm not gonna take my rear end apart to just grease it and have that problem come back....if the traction bars are easy to install then i'll just do that...there cheap and it seems that they will fix this problem me i guess. I just want to make sure this won't cause damage to the rear end if say i do nothing at all. this jerk is "normal" for the most part and not anything serious.
Let me know: slip yoke greased or traction bar install???
thanks guys
Old Oct 10, 2006
thanks guys
Grease the slip yoke 1~3 times a year or install the JD's once and be done with it. I know what I would do. In fact, it's what I did.
Old Oct 10, 2006
Blhde's Avatar
It also kinda sounds like the sticking rear drums. Which only happens on cool moist mornings, once the brakes warm up it goes away.
Maybe a combo of both?
Old Oct 11, 2006
whippersnapper02's Avatar
My truck makes a clunk too. Its a stick so i happens all the time. Would it be the U-joints? It clunks loudly when i shift gears and when its in 4WD the front does it too. Also i get a clunk from the rear end when im offroading. C-clips? Help
kendawg
Sep 5, 2020 09:56 AM
Crunchy
Oct 7, 2013 09:00 AM
97ranger666
Oct 9, 2011 11:36 AM
MLWilley
May 31, 2011 06:20 AM
Crunchy
26
Feb 28, 2008 07:15 PM
