Dana 35 drain bolt installed
Old Oct 1, 2006
98+ Ranger 4x4's have a D35 front differential that is positioned with its cover plate right up next to a crossmember. That makes it impossible to pull the cover to change the diff fluid in the usual way. The procedure in the factory manual is to use a pump to remove the fluid through the fill hole.
I drilled and tapped the diff case for this low profile motorcycle drain plug to make it easier to do fluid changes. It is tucked up next to and behind two heavy stiffening ribs in the diff case which should make it safe enough for the offroading I usually do. I might someday make set of diff skid plates and include an access hole to the plug.
This type of drain plug is not for every truck. The aluminum case is thin (~3/16") and it would be easy enough to strip the threads if you treated it like the fill plug. I know its limitations and nobody works on my truck but me so I think it will live.
Old Oct 1, 2006
rangererv's Avatar
u wernt worried about metal shavings in the diff case?
good idea tho, seems simple enough
Old Oct 1, 2006
Good job, Bob! I don't have a D35 front diff (or any front diff yet for that matter) but I like it.
I have the Explorer finned aluminum rear cover and I really appreciate the drain plug in it.
Old Oct 1, 2006
looks good bob that will definatly make the job easier, i actually dont think it is too bad just to drop the whole diff and drain it. but it will require some help from a friend.
was the oil even dirty? I had mine changed at 40k miles and it wasnt bad at all. and i changed it again when i did the gears and it still wasnt dirty.
Old Oct 1, 2006
I did it off the truck so no shavings to worry about. A brave person might drill it in place and flush the shaving out through the drain hole. I guess I'm not that brave.
Old Oct 1, 2006
rangererv's Avatar
i c, thats good u did it off the truck.
Old Oct 1, 2006
shadyluke's Avatar
Props Bob. You been hitting the mods hard lately. Nice to see. Plus it gives everyone else some ideas.
Old Oct 23, 2006
how do u drop the diff?
1)so i can drain and fill the fluid possibly make a drain hole
and also
2) so if/when i get a front locker i know how to drop it..
Old Oct 23, 2006
and also
This covers it:
https://www.ranger-forums.com/forum2...ad.php?t=29506
Old Oct 23, 2006
thanks
Old Oct 23, 2006
Nicely done, that is a great idea
Old Oct 24, 2006
Cool I dont have a front diff but cool idea!
Tys 4x4 FTW
75
May 11, 2011 10:28 AM
1996Ranger4x4SuperCabSTX
OLD - Engine & Drivetrain
Nov 30, 2009 09:05 AM
Nov 6, 2009 10:46 AM
freddie
19
May 27, 2009 06:13 AM
optikal illushun
Jul 28, 2005 12:54 AM
