My Explorer Axle swap done (pics)!
Old Aug 18, 2007
DerangedPony's Avatar
Well, after waiting for parts to come in the mail and for some free time, my axle swap is finally done. After getting all the parts together, the swap was relatively easy. The truck drives nice and straight. The Aussie locker is very quiet when driving and has good road manners.
Old Aug 18, 2007
Rooks's Avatar
Looks awesome.
Old Aug 18, 2007
4x404Edge's Avatar
Is the explorer axle wider then a stock ranger axle? If so can you notice the difference with the width?
Old Aug 18, 2007
bwester04's Avatar
^yeah can you get a pic of the back of the truck, im curious to that as well. I like the cover as well, it's different.
Old Aug 18, 2007
KARPE's Avatar
Explorer is an 8.8 stock Ranger is 7.5, I always assumed that was width, but you know, I have never seen any unit of measure attached to that quantity.
Old Aug 18, 2007
KARPE's Avatar
Explorer is an 8.8 stock Ranger is 7.5, I always assumed that was width, but you know, I have never seen any unit of measure attached to that quantity. Although it's probably diameter of the shafts.
Old Aug 18, 2007
nbro3232's Avatar
explorer 8.8 is 1.5" wider than ranger 8.8, so .75" each side
Old Aug 18, 2007
edit your first post man..
it came out nice, i like it
as for the diff cover, is that the one thats made out of what, 3/8" steel? i keep forgetting where it came from..
Old Aug 18, 2007
looks great man! very nice!
Old Aug 18, 2007
Yeah, it's from a to z fab, here is the post I made before the paint:
https://www.ranger-forums.com/forum2...ad.php?t=48340
Here are a couple more pics so you can get a better idea of the width.
Old Aug 18, 2007
looks good...
Old Aug 18, 2007
you can hardly tell, it looks good.
Old Aug 19, 2007
4x404Edge's Avatar
The numbers 8.8 and 7.5 has nothing to do with the width of the axle what so ever. Thats the ring gear size. Also Rangers come stock with 8.8's. Its just the explorers have a 31 spline 8.8 which is stronger then the rangers 28 spline!
Old Aug 19, 2007
4x404Edge's Avatar
I think the truck looks great. But IMO i think it would look even better with a little wider tire. Those 10.5 inch tires just aren't wide enough for that amount of lift. Wish i had a 31 spline 8.8. Then id be running an OX Locker!
Old Aug 20, 2007
Joush's Avatar
I was just wondering if the bolts came with the cover? The cover I have is counter sunk and the stock bolts don't seem to fit.
Old Aug 20, 2007
My05edge's Avatar
i think some 1 1/2 inch wheel spacers would make it look better
Old Aug 20, 2007
looks really good
Old Aug 20, 2007
No, I just went to ace hardware and picked up some longer allen head bolts and lock washers. I also could not fit the stock bolts, and I didnt even want to considering how much thicker the cover is.
Old Aug 20, 2007
I hate when tires stick out from the fender flares. I got skinny tires because I like them tall and skinny.....the same way I like my women.
Old Sep 3, 2007
Matt3203's Avatar
ok i had a question do the shock point match up when you switch axles, cause i can get one for free, but i dont wanna switch if its gonna be hard work
Old Sep 3, 2007
No, you need to weld on new shock mounts.
Old Sep 5, 2007
ThisWeekendsRepair's Avatar
Is there anything that you have to do to the brake master cylinder when you switch from drums to disk? I thought drums work on higher pressure than disks. How about the anti-lock system? Any changes there with the RABS gizmo? Just asking, and thanks for the info.
Old Sep 12, 2007
D94R's Avatar
At what point do you trade driving safety with looks? I'd think anything above a stock 4X4 Ranger lift should require a wider stance if anything for stability while manuvering, looks aside. Otherwise you create a very unstable platform for panick manuvering should the occasion occure, and look like a stilt driving down the road. Hell look at the pics on here of lifted Rangers that have rolled over, I don't recall any of them who didn't have wider rim/tires, and look how easily they rolled. How much easier do you think it is with pizza cutters?
Old Sep 12, 2007
Nothing in the rest of the brake system needed to be changed over for the install. As for the anti-lock, I wouldnt know because I do not have abs on my truck.......anymore.
Old Sep 12, 2007
AgPete139's Avatar
If you have a rear ABS, you are fine with jsut the axle. The explorer master cylinder is recommended (but not always necessary), and if you don't have ABS you definitely need it. Make sure to get the parking brake extensions and hardware. You will need to relocate shock mounts and you will prolly wanna convert to a spring over axle (SOA) setup which requires welding, since it's more reliable.
For 10.25" drums, get a 1991 - 1994 exploder. For discs, get a 95-2001 exploder. After 2001, they have an independant rear suspension and the live axle setups were abolished.
Does this clear up any questions?
I hope that all of you know the differences between the ranger 8.8, ranger 7.5, and explorer 8.8 by now...
edwards1687
22
Aug 26, 2021 08:34 PM
rngprerunner
Engine & Drivetrain
Jul 10, 2016 11:39 PM
thef9est1
Nov 1, 2010 09:17 PM
88RangerGT
Jun 25, 2005 07:23 PM
