Manual to Automatic 01 XLT 3.0
Old Nov 20, 2007
sdproject's Avatar
Icon5 Manual to Automatic 01 XLT 3.0
Is it possible and if so whats all involved in swaping out the 5spd for an auto matic trans. Its a 2001 XLT 3.0 extend cab. Any info is greatly appreciated!
Old Nov 20, 2007
wvcat's Avatar
For starters...
Trans
Steering Column
Shift Cable
Wiring Harness
PCM
ECU
Cluster with dispay for automatic
Brake Pedal
Carpet
Others can chime in if I forgot something
John
Old Nov 21, 2007
sdproject's Avatar
Thanks for the info.
Old Nov 21, 2007
greygooseranger's Avatar
You don't need the steering column if you just install a floor shifter. You can remove your clutch and re-use the brake assembly that came in the truck. If you put a floor shifter in, then you don't need to screw with the dash and the gear selector display. I don't see why you would need different carpet either...
Old Nov 21, 2007
wvcat's Avatar
Yeah your right you can get away without carpet. I was assuming a stock look, so it wouldn't look "messed with" (shifter, cluster...)
Old Nov 21, 2007
Dangeranger3's Avatar
Ranger autos are junk. You're much better off sticking with the manual. This is the opposite of the swap people usually do. Most swap autos for manuals b/c they're tired of putting new trannys in and would rather just replace a clutch.
Edit: Added more info
Old Nov 21, 2007
The only problem is that the slave cylinder is a big ole pile of sh*t in the manual. The only way to go is a manual T-5 but they only mate to a 4.0 ranger. I would like to put an auto in my truck, but it would be a GM 700R4 like GRANITEGUY did, and it would be for towing purposes...
Old Nov 21, 2007
sdproject's Avatar
Hey guys thanks for all the info . I guess I'll stick with my manual trans.
Old Nov 22, 2007
yea...700r4 conversion. You can use your current computer, use a floor shifter, get an adapter, get your shaft modified, and your done. I want to do it. kinda.
04blackedge
May 7, 2009 04:43 PM
jaycheetwood
21
Sep 22, 2008 10:23 PM
b3kbruiser
Mar 5, 2007 06:10 PM
BoeingMan
Jul 13, 2005 09:03 PM
BoeingMan
Jul 13, 2005 06:43 AM
