Cant get oil filter off need ideas
Old 03-06-2008
Ace's Avatar
Ace
Ace is offline
well the title pretty much sums it up i cant get that fckin thing off im tempted to put a screw driver though it but im afraid that wont work and it will fck it up even more.
Old 03-06-2008
Nope, screwdriver method is your best bet. Just make sure you dont miss and stap a hose or something lol.
Old 03-06-2008
Ace's Avatar
Ace
Ace is offline
ah hell wish me luck...
Old 03-06-2008
yep had to do the screwdriver trick on my cousins grand prix, let us know how it goes, should work
good luck
Old 03-06-2008
Ace's Avatar
Ace
Ace is offline
Not working LOl would it hurt anything if i just took a hammer and beat the **** out of it?
Old 03-06-2008
So you can't put a hole in it? I thought you just needed to break the seal?
Old 03-06-2008
chevyslayer925's Avatar
dont u have an oil filter wrench or anythin? take channel locks to it, trust me itll come off ur gonna have to squeeze real hard and push pull, i wudnt beat it with a hammer ur liable to damage where it mounts...if i cud remember wat thats called
Old 03-06-2008
I didn't even think to ask that, how are you trying to take it off?
Old 03-06-2008
Ace's Avatar
Ace
Ace is offline
I have one of those Octagon shaped things but its doing no good at all it just slips i've tried 3 different one of those. i tried to put a screw driver though the middle but dont have a whole lot of room to work with to hammer it in.
Old 03-06-2008
Worse comes to worse, you could drill a hole in it.
Old 03-06-2008
heaton84's Avatar
Invest in a good oil filter removal tool. It looks like a wrench but it has a chain that bites back onto the tool. Slip it over the filter and you have a lever.
Or use the screwdriver method (never heard of that before but I could see it working).
Old 03-06-2008
Channel locks...or if theres a sears near you go to sears they have the tool u need its 13 bucks,they sell a cheaper one but it doesnt work trust me ive used it..
Old 03-06-2008
Boowak's Avatar
It's most likely just the air pressure built up inside. If you tighten it too much when you put it on it'll do that. In which case you probably just need to push or pull on it as hard as you can. Maybe you should even have someone doing it with you as hard as they can. I kind of had the same problem. Damn dealership mechanics didn't know anything, I swear.
Old 03-06-2008
Channel locks. My girlfriends dad insists on cranking on them till they don't move with those stupid cap things, and it just makes taking them off so darn hard, especially in a little honda civic where there is maybe 2 inches of clearance near it.
Old 03-06-2008
Ace's Avatar
Ace
Ace is offline
whats this tool i need called i might have it.
here is what i've done to the filter....
Old 03-06-2008
rangerdan01's Avatar
the rubber strap wrenches from sears, worth the money.
Old 03-06-2008
Ace's Avatar
Ace
Ace is offline
I dont have enough room to use one of those... i've tried them lol
Old 03-06-2008
Its cause your using a Fram filter! Those things are junk. It seems like the gasket is just stuck to the block. The rubber strap would be the best thing, so is there any way at all you can get one up there?
Old 03-06-2008
Ace's Avatar
Ace
Ace is offline
i can get it up there but i cant get it to close
you are talking about the little blue handle thign right?
Old 03-06-2008
Yeah thats what I'm talking about.
Old 03-06-2008
Ace's Avatar
Ace
Ace is offline
ya i dont have enough room to a make it grip on to the filter
Old 03-06-2008
07Ranger's Avatar
lol did u happen to put oil on the seal when u installed the new one...i BET you didnt :)
thats y its a ***** to get off. :) oil filter wrench FTW
make sure you put the screwdriver all the way through the filter so it sticks out the other side then try it. If that method doesnt work....start crying!
Old 03-06-2008
Ace's Avatar
Ace
Ace is offline
yes i put the oil seal on and took the old one off, my friend is gonna come over in a bit and we will see what we can do....
Old 03-06-2008
filter pliers.
Old 03-06-2008
mroctober16's Avatar
just get one of those extra long screwdrivers and hammer that sob threw the filter.
Quick Reply: Cant get oil filter off need ideas
