Sponsored by: DashLynx
Cant get oil filter off need ideas
Old 03-06-2008
It depends where it is on the filter, he took a good chunk out of it.
  #52
Old 03-06-2008
Ace's Avatar
Ace
Ace is offline
It really isnt that big of a hole i could prbly put a piece of plastic over the hole then put putty over that.
  #53
Old 03-06-2008
SparkYZ's Avatar
I wouldnt risk it. Jam a screwdriver clean thru both sides and turn it like an 1/8 or 1/4 of an inch, as much as you can, and hopefully that will break the seal.
For your next filter, if you really wanna avoid this problem, use a K&N oil filter...It's got a 1'' nut welded to it!
  #54
Old 03-06-2008
Ace's Avatar
Ace
Ace is offline
thats the thing i've checked local stores like Farm and fleet and wal-mart and kmart doesn't even have this stuff. Those are the only stores that are around here and all they have are those FRAM filters where would i get a k&N one?
  #55
Old 03-07-2008
do you have a checkers or a schucks, autozone? they usually have k&n filters
  #56
Old 03-07-2008
Autozone will have them. I use the Motorcraft filters and I've never had a problem popping them off.
  #57
Old 03-07-2008
Ace's Avatar
Ace
Ace is offline
hmm autozone is about 20 min away i think... what about like orielys ? or advance
  #58
Old 03-07-2008
Yeah any place like that should have them Autozone is just the one closest to me.
  #59
Old 03-07-2008
Just an FYI, I am a volkswagen guy, and a tech teacher (Dan J Reed) on the website vwvortex did a test on a k&n filter, and well basically, they suck.
Always use and OEM (Motorcraft) on your car.
  #60
Old 03-07-2008
WowMike2001's Avatar
Thats exactly what happened to me when I tried changing my oil for the first time right after I bought my truck..
I tried everything, finally had to resort to grabbing a long breaker bar to use as a hammer, and a screwdriver.. pounded it through both sides, and used that as a hand hold to crank it until it popped loose.. Then I put on a proper filter, and made sure to put some clean new oil on the top seal.. when i changed it about a thousand miles ago it slid off nice and neat with two hands twisting it off with a bit of effort.. just how it shoudl be =)
  #61
Old 03-07-2008
OTRtech's Avatar
I've used a plumbers chain wrench.In fact as I was wandering through Harbor Freight the other day , they had one on the shelf that takes a 3/8 drive .
  #62
Old 03-07-2008
Rolldogg's Avatar
3 pages and it's not solved yet............someone drive over there and give the poor SOB a helping hand. It's like watching a bird twitching after it got hit by a car.
List in which to remove an oil filter.
1 - Hand (for the young guy)
2 - Oil filter removal tool (most of us DIY'ers use this)
3 - Channel locks (if you can get them in there)
4 - Screwdriver through the bloody thing!!!!
......and if it still isn't coming off......well that will teach you for either a) putting it on WAAAY too tight, or b) buying a cheap @ss filter where the seal *REALLY* sealed on there.
  #63
Old 03-07-2008
Ace's Avatar
Ace
Ace is offline
lol got it off
  #64
Old 03-07-2008
How did you get it off?
I use something like this but mine wraps more around the filter
  #65
Old 03-07-2008
Ace's Avatar
Ace
Ace is offline
Channel locks and i tried to use those but didn't have enough clearance to use it properly.
  #66
Old 03-07-2008
SparkYZ's Avatar
You beat the hell out of that filter!
K&N Filters were shown to be good filters in a few 4x4 magazines I read (yeah yeah I know, doesnt say anything)
Cut apart a Fram and cut apart a K&N and compare the amount of filter media
  #67
Old 03-07-2008
chevyslayer925's Avatar
wats wrong with fram...i used the Fram tough gaurd stuff...never had a problem with it.
  #68
Old 03-07-2008
SparkYZ's Avatar
Old 03-07-2008
OTRtech's Avatar
Now how bout some pics of what's left of your knuckles ?
  #70
Old 03-07-2008
jrpro130's Avatar
I had this happen on the atv. I ended up getting a filter wrench (like an adjustable spanner wrench) and EVENTUALLY got it off. It took a lot.
also strap wrench will work.
I had this happen to me even after I oiled the seal...I dunno what the problem is.
  #71
Old 03-07-2008
Ace's Avatar
Ace
Ace is offline
Why cant all the filters have one of those things at the bottom like the K&N's
  #72
Old 03-07-2008
whippersnapper02's Avatar
The K&N doesn't look so bad. No cardboard in it.
  #73
Old 03-07-2008
SparkYZ's Avatar
You also pay out the teeth for a K&N, 11 bucks as opposed to 3. They claim the sides of the can are stronger too for rocks getting flung up there and such...
  #74
Old 03-07-2008
Well I pay about 9 for the Mobile One that I use now so whats a few more bucks. Also I can get them for $8. Another thing is I'm going to start changing my oil every 5K instead of every 3K.
Originally Posted by SparkYZ
Note To Self: 4LO DOES NOT MEAN INVINCIBLE!!
LOL. I have to remind myself that sometimes.
  #75
Old 03-07-2008
Ace's Avatar
Ace
Ace is offline
lol i cant believe this thread got 3 pages long...
Quick Reply: Cant get oil filter off need ideas
