'83-'97 Twin Traction Beam (TTB) information.....(sticky?)
Old Mar 17, 2008
Old Mar 18, 2008
bump.....
Old Mar 19, 2008
NsTyFoX's Avatar
great right up
Old Mar 21, 2008
stRanger's Avatar
Did you mention that they can be a PITA to keep aligned? Had skyjacker 2" lift springs on my old ranger and had to get it aligned about every 3-6months
Old Mar 21, 2008
sounds like that was an extra problem....i had the alignment on my '97 for almost 2 years and when i had the ball joints replaced, it was still almost dead on...
Old Mar 21, 2008
stRanger's Avatar
mighta been due to the lift coils and no drop bracket.. I had some of the biggest adjustment cams that you could get..... but those skyjacker leveling coils flexed pretty good!
Old Mar 21, 2008
Dangeranger3's Avatar
ttb/tib pwns 98+ shat and pinion and torsen bars
Old Mar 21, 2008
Hardwareman's Avatar
Sounds like you're starting to miss your old Ranger there buddy?
Allen
Old Mar 21, 2008
Allen
Amazingly, I don't miss it at all....I am having way too much fun with the Bronco II!
Old Mar 21, 2008
Well glad to hear that! Honestly.
I'm thinking if I get rid of mine I'll regret it but you prove otherwise. Good man!
Allen
Old Mar 25, 2008
jolliffem's Avatar
Maurice is there a reason why you wouldn't buy the 4" Superlift lift kit instead of an 6" if you are going to use the 4" mounting holes on the bracket anyways? What about the coils and shocks being used with it that are 6", not an issue?
The plan is now to stick with 31's and get the 5.5" Superlift, but use it at the 4" height, this is assuming that the longer front coils and shocks is not a problem.
Old Mar 25, 2008
The 4" lift hole with 6" springs is for the supercab 4.0 Rangers ONLY......the extra weight of the supercab and the 4.0 allow the truck to be aligned properly....the mounting point of the TTB beams need to be dead center of the wheel hub....
you can buy a 4" lift and then buy 6" lift coil seperate if it is cheaper....
Old Mar 25, 2008
good write up
Old Mar 25, 2008
Wolgun's Avatar
seems like i need to up grade
Old Mar 25, 2008
the Dana 35 is much stronger than the Dana 28....if you are running large tires and are beating it off road, upgrading should be an upgrade....
the Dana 35 is a DIRECT bolt in for the Dana 28....
HouseofFinch
Sep 11, 2022 04:13 PM
Ranger093
Jan 3, 2011 02:51 AM
PaulWilks
OLD - Engine & Drivetrain
Nov 1, 2010 05:18 PM
b4k4x494
Apr 25, 2008 10:42 AM
4.0ltwins
Apr 21, 2008 08:24 AM
