My coilover swap has begun!!!!
Old Apr 22, 2008
MudSlanger's Avatar
As some of you know, im Superlifted and i hate Torsion Bars. I decided today was a good day to call up RCD and buy some hardware to do the swap. I got everything i need on order and im excited.
My coilover swap is now OFFICIALLY in PROGRESS.
Here is a little bit of info on what i ordered here:
Driver Side:
Upper 20-52498-9
Lower 20-52498-11
2 Gussets 20-52498-17
Spacers 20-833167
Passenger Side:
Upper 20-52498-9
Lower 20-52498-12
Spacers 20-833167
Cost me about 185 bucks for all of the RCD stuff.
Now its time to order me some 12" 750# hypercoils and Fox Shocks.
And here is the specs of the Shocks ill be getting:
The 2.0x6.5 shock from Fox:
Shock Travel: 6.50"
Extended Length: 19.35"
Collasped Length: 12.85"
Shaft size is: 5/8"
Fox Part #: 980-99-001A
Old Apr 22, 2008
sullys_ranger's Avatar
Sounds good man! You have to have a superlift to do this?? Id like to have the plush ride of coils rather than the torsion bars. Cant wait to see it done!
Old Apr 22, 2008
If you get coils that are 4" shorter I bet it would work stock.
Old Apr 22, 2008
MudSlanger's Avatar
You might be right!!!
Old Apr 22, 2008
i want to do this sooo baddd! i might just have to order exactly what you got right now! lol. jk. im poor.
Old Apr 22, 2008
MudSlanger's Avatar
haha, put some bubble gum on your shocks and call it a day, it will give you 3 inches of lift EASY when it blows bubbles!
Old Apr 22, 2008
nice. post up pictures when you get this done.
Don't forget, you will have to make/fab an upper coil over mount!
Old Apr 22, 2008
MudSlanger's Avatar
Who says?
Old Apr 22, 2008
MudSlanger's Avatar
are you sure?
Old Apr 22, 2008
whose is that? that looks awesome.
Old Apr 22, 2008
MudSlanger's Avatar
Its someones off an explorer forum who did pretty much the same thing as me!
Old Apr 22, 2008
Thats mine you liar!
Old Apr 22, 2008
MudSlanger's Avatar
In that pic, i dont see any upper coil over mount!
Old Apr 22, 2008
Guess not, but you will have to strengthen that upper shock mount. I can guarantee you it isn't rated to carry the weight of the truck.
Old Apr 22, 2008
MudSlanger's Avatar
I know, thats why i ordered the gussets to weld on to the upper mount. They are like 3 bucks each
Sorry, changed tabs to gussets on my parts listings up there so i dont confuse anyone!
Old Apr 22, 2008
this is gonna be awesome when your done! can't wait to see how it turns out so that way i can order the parts to do mine. i cant stand torsion bars!!!!!
Old Apr 22, 2008
Woods-Rider's Avatar
Diddo!
$185 for parts is pretty cheap. if you dont mind me asking how much did the coilovers run you, shocks and coils?
Oh, and what about control arms (if that is what they are called for ifs), i didnt see them on your list, but they are part of the RCD kit.
Old Apr 22, 2008
MudSlanger's Avatar
As far as im concerned, all i need are those brackets that I supplied part numbers for. No other parts are needed.
Coils are gonna run me about 135 bucks and the Fox Shocks will run me about 420 bucks all shipped. So im lookin to spend about another 555 dollars just to finish this swap!! no big deal!
Old Apr 22, 2008
you could make a new mount for the top..its a basic part from RCD..i could take measurements on mine..and make some at work..piece of cake
Old Apr 22, 2008
MudSlanger's Avatar
oh well, already ordered lol
Old Apr 22, 2008
06fx4 L2's Avatar
looks like the coil is hitting the axle on the explorer.
JOSH
Old Apr 22, 2008
So you dont need these (in the red circles)? Sorry, I'm not too familiar with the RCD kit.
Old Apr 22, 2008
MudSlanger's Avatar
where do those connect to? But the people who have done the conversion on their explorers have said NOTHING about those circled parts!
Old Apr 22, 2008
MudSlanger's Avatar
JOSH
Bad angle.. They sit no closer than the struts that come with the superlift!!!
Old Apr 22, 2008
RangerNVS's Avatar
As far as the "Links" that connect to the LCA's I have read nothing about those. I think that this mod, could be very insightful to those who have a Superlift that want to get rid of torsion bars. The upper shock mount does need to be beefed up, hence the reason for the shock gusset's, that come "NORMALLY" with the RCD 5.5 lift kit for the Fourwheel drive lift kit. Basically all you are doing is taking away the torsion bars, and retaining the weight of the vehicle with the coilover setup. I don't see the need for those links, being that the LCA's are fixed via the two mounting bolts and the diff brackets for the Superlift kit bolt into the stock location. Why would you need them. Anyone have any idea's? Also here is the link that we and Integra have been reading over and over again.
http://www.explorerforum.com/forums/...=RCD+SUPERLIFT
