another $100 junk yard find!
Unregistered User
Posts: n/a
Unregistered User
Posts: n/a
everything is in good shape, minor cleaning and machining of the rotors.
i wont be cleaning and painting things as i live on a dirt road and will just trash them anyway off roading.
Unregistered User
Posts: n/a
Unregistered User
Posts: n/a
well somewhat bad news, the bolt pattern is a tad different, so some grinding and welding was needed.
all cleaned up and ready to go.
finished product
i had to grind the holes out a tad on the caliper bracket, so for extra measure i just welded it to the housing as well as bolted it. i dont care if its permanent , i even entertained welding it all the way around!
the brake hose bracket i just simply bolted to the spring perch and used a self tapper. then cut the line and re-flared it to a bubble flare. bled the system and all is good
next week i'll see if i can get the parking brake hooked up. i can say this, it stops a lot different now!
finished product
Unregistered User
Posts: n/a
why? i already have 4.56's and a loc-rite.
that would have been more work welding on spring perches and shock mounts, swapping gears and needing a new locker. and cost way more then 100 bucks.
the explorer rotors are almost identical and so are the pads.
i have maybe 3 hours of my time into this.
