braking isssues, bucking and locking up
Old Jul 10, 2008
wolfman00's Avatar
heres the deal, when i hit the brakes, doesnt matter if its wet or dry the rear will shake a bit and at times, the rear drums will lock up when i brake. Also, when i lightly hit the brake, it grabs really hard. The odd part is that it doesnt do it all the time, but its happening more and more and concerns me.
I was thinking maybe the master cyclinder had something to do with the locking up part. (it only locks up on one side), as that happend on my brothers '99 ranger too.
The shuddering and shaking part i dont get. Anyone had anything like this happen or and idea what it could be?
I want to get it fixed soon, haha.
Old Jul 10, 2008
skaven's Avatar
my wheel barings on my rear end when they were going they would lock up with my brakes...might be that
Old Jul 10, 2008
leadfoot's Avatar
The Abs sensor is in the diff housing. So if you still have an open diff it is possible for one side to completely lock up as long as the other wheel is still turning. When I replaced only one rear wheel brake clinder it woked more efficiently than the other side causing it to lock up. When it is about to lock up it does have a shudder feeling.
Old Jul 12, 2008
wolfman00's Avatar
still havent figured it out, any more ideas?
Old Jul 12, 2008
The shakin part could be caused by having warped rotors up front. How bad is the shake?
Old Jul 12, 2008
wolfman00's Avatar
well, i loosened up my rear passanger drum alot and it seems to not shake. The pads are fried though. im taking in on monday though to get it all checked out and replace what needs replacing.
Old Jul 12, 2008
00Ranger's Avatar
i had this happen to me, i ended up just polishing and changing the pads. it works fine for me now.
Old Jul 12, 2008
ONEDGE04's Avatar
Usually the front brakes are shot and/or your back brakes are too tight. Being light in the rear will cause the lock up. Have the drums turned if they need it and just don't over tighten the new pads.
Old Jul 14, 2008
TireIron's Avatar
if its just one side locking up dont overlook your ebrake cables. If one of those is rusted up it can easily cause the rears to be locking up all the time.
Old Jul 17, 2008
wolfman00's Avatar
update, got brakes fixed, thought we had it. this moring on the way back from fishing i smelled the pads roasting, and smoke poured off the passanger side. got soo hot the wheel weights fell of the wheel on that side. they are now locked up on that side.
so its definitly broke now at least. now hopefully we can figure out what the deal is with it.
Old Jul 17, 2008
That sucks. I take it back to the brakes place, or did you do it yourself?
Old Jul 17, 2008
wolfman00's Avatar
na, i have a mechanic that does all my work, he has done all the lift kits on my trucks too. Im pretty sure something just popped loose like a spring or something.
Only thing that sucked was i had to run home, get my dads powerstroke, the trailer, load it up, and then take it over there. That took about two hours alone. But, we did go fishing first and we did catch a few so at least we had that right, haha. I would have been even more mad if the truck broke and i didnt catch anything. that would have just plain been bad. haha
Old Jul 17, 2008
JakeH05's Avatar
mine lock up when i get mud, sand, or sometimes water in them. Rangers tend to be bad about this when wheelin. Sounds like u have a different problem tho if they locked down on ya.
Old Jul 17, 2008
Thorny073's Avatar
i use to have a dodge dakota that did the same thing when i was done wheelin...that was always a fun ride to get her cleaned up
Old Jul 17, 2008
Blhde's Avatar
I have had the shoe come apart and wedge between the other shoe and drum. It got so hot it warped the drum.
I have also have had a wheel cylinder leak and cause the locking up issue.
Old Jul 18, 2008
TireIron's Avatar
yea, with how hot it got I would also check for a warped drum and even a warped rim if it got too hot.
Old Jul 20, 2008
wolfman00's Avatar
well, we got it fixed for the most part, somehow the e brake was catching the adjuster and cranking up the brakes each time i put the parking brake down. strange, and i still have no idea how it could happen. he was boggled too, so we teaked it some but now i have very little braking, so i adjusted them up some. should be good.
but, if i keep having problems, im going to look into rear disks from an exp.
there is a write up on here somewhere isnt it? i couldnt find it...
Old Jul 23, 2008
wolfman00's Avatar
still doing it. rear drum smoked its *** off today. what the hell is causing it??
Old Jul 23, 2008
did you bleed the lines? new cylinders? what about drums and pads? i am not sure what you all replaced the last time.
Old Jul 23, 2008
wolfman00's Avatar
well right now the only thing replaced was pads. Its obviously going to go deeper than that im sure, haha. Few things i noticed- not as much pedal as before and i checked the fluid, have plenty but could be changed as its dirty as hell. drivers side is good though.
passanger side, dont see any wetness around the wheel cylinder. My only idea is that the parking brake is still cranking up the adjuster somehow, which i cant figure out how on earth its doing it. makes not sense to me at all haha.
Old Jul 24, 2008
wolfman00's Avatar
well, figured it out. frozen ebrake cable on the right side.
Old May 20, 2009
02rangermayhem's Avatar
thank you ranger-forums... once again here to save the day.
soulrobber
Dec 6, 2018 03:49 PM
Phil99xlt
OLD - Engine & Drivetrain
May 26, 2013 08:39 PM
monkeysteeler12
20
Mar 8, 2009 05:18 PM
Shaklakan
Feb 23, 2009 10:03 AM
FMD
Jan 10, 2007 08:51 PM
