how to, inner tie rods
Old Nov 20, 2008
Do these need to be replaced normally? You need a better camera man lol
Old Nov 20, 2008
you had the special tool, why did you remove the rack? if you have that tool the ford manual says you dont have to remove the rack.
I did this once, completely sucks, one of the worse things i have ever worked on. luckily you had a lift.
Bill and I had nothing but jack stands.
The worst part is getting that piece of junk out of the sub frame.
Old Nov 20, 2008
djphibes's Avatar
Thanks for the pics and how-to! Looks like a PITA job, but good to see how it's done.
Old Nov 20, 2008
Ditto? Justin did my passenger inner in about 15 min maybe 20? with out removing the rack?
Old Nov 20, 2008
seminaryranger's Avatar
Thanks for the How-To!
I need to do this on my 2wd.
Is the procedure any different on a 98+ 2wd truck? It looks like the rack sits "in" the cross member on 4wd trucks whereas it sits "on" a cross member on the 2wd trucks?
Old Nov 20, 2008
god that alignment rack looks old as ****
good job on the install
Old Nov 20, 2008
Mark98xlt's Avatar
I did a total of 3 crappy re manufactured napa racks on my 98, can do it in about an hour lol...
Old Nov 20, 2008
Toreador4x4's Avatar
Ive done numerous ranger and other inner tie rod ends and never ever have removed the rack to do so
why no zipties? motorcraft inners come with zipties
also, why did yo have to remove the bushings? maybe im missing something
If you have the tool that mark is using, which i do, they are a piece of cake
Old Nov 21, 2008
buckgnarly's Avatar
zip tie has held on mine for a year and about 20k.....now that I said it, it will go....
I think my bushings are shot, so I'll be using this next time....
Old Nov 21, 2008
john93rangerstx's Avatar
i have zip ties on mine it cam with the boot when i got the boot from autozone
Old Nov 21, 2008
RockysFord's Avatar
Yeah, good how to, but i agree with the others...
Through the pictures im like "Why is the rack being removed??"
Made it 90% harder than it is...
And every car and truck i do at work, i zip tie the rubber boots back on, or use a heater hose clamp with a swivel 1/4" wratchet..
Old Nov 21, 2008
I do agree on that part, do not use a pipe wrench, and do not use an impact gun with the tie rod end tool, unless you want to spin half of the rack off with the inner tie rod end.
Old Nov 21, 2008
i agree too, your bound to ruin that rack if those tools are used.
Old Nov 21, 2008
Mark just checked FORD tech service on a 2004 torsion bar ranger just like yours.. it does not anywhere instruct to remove the rack....
I am not saying this is bad to do just saying its not needed...
also i agree zip ties are not the best at all but will work till ford clips or atleast hose claps are used..
Old Nov 22, 2008
PUNKROCKPILOT's Avatar
my truck is definately due for inners again....... thanks for the reminder:(
im not pulling my rack out and im gonna use whatever wrench i happen to have!
im just waiting to totally wear out my front tires (which should be soon) then replace both inner and outer then brand new BFG's!!!! Woo-hoo! but what i really want to do is put in a D44...... dream alittle dream.
beelertank
May 17, 2011 04:37 PM
rideac1
Apr 22, 2009 06:48 AM
Crunchy
Feb 11, 2009 04:42 PM
billj
Nov 14, 2006 08:15 PM
billj
Nov 8, 2006 08:46 PM
