4x4 swap
You don't need new brake pads or calipers unless your current ones are worn out. You will need new rotors though. They differ from 4x2 to 4x4. Since you have a donor truck why not use the rotors off that truck? If they are shot or something you can just buy a set of rotors for a 2000 4x4. They should be the 11.25" rotors. In 2003 they switched to a 12" rotor and you can't use those unless you're using a knuckle from a 2003 or newer truck.
