Recovery Strap question
Old Jan 28, 2009
Mykhael's Avatar
Okay so I pulled that Dodge out yesterday he had tow hooks.
I came across someone today and it was just a car no where to hook up.
I got one of these. if the vehicle your pulling out doesn't have a hook or anything how do you do it?
Old Jan 28, 2009
you cant?
unless theres something to hook the D shackle through.
if a car just slid off the road and needs to be drug back onto it, one of those straps with hooks on it will work
Old Jan 28, 2009
You can wrap a tree saver strap around a crossmember, then join both ends with the recovery strap with a shackle. But if it just slid off the road a normal tow strap will still be fine.
Old Jan 28, 2009
Mykhael's Avatar
Originally Posted by 99ranger4x4
you cant?
The kind I had that I got flamed for using when I went wheeling with jeweler?
Old Jan 28, 2009
I generally take it easy. I find a hole in the frame and hook my tow strap to it. yes...tow strap as the hooks are small enough to hook into any hole in the frame. OR i find a crossmember to hook to, or a control arm. And i'm very careful when that strap it hooked up. And if i'm able to use a recovery strap, i use it whenever possible.
I've got something similar to those too...
Old Jan 28, 2009
Theres a difference between pulling a car back on the road and getting someone un stuck.
Old Jan 28, 2009
malydeen's Avatar
Thats how I pulled David (ranger_guy15) out when he went straight off the road and through the snow bank.
He didnt have a rear recovery point, so I just hooked a hook through a random hole in the frame and did a nice easy pull. Most cars have a loop or something in the back to pull from. if not there should be an oval hole at about a 45* angle that is reinforced that you can pull from. Its the same hole that a tow truck J-hook would go into.
And I towed a chevy 2500 3 miles home with a strap just like that.
Old Jan 28, 2009
exactly
gently pulling someone out of a ditch isn't putting nearly as much of a load on the strap compared to yanking someone out of a mud pit.
Old Jan 28, 2009
crazymikey's Avatar
I use my clevis hooked tow strap for vehicle recoveries all the time (about 7 so far). I just make sure that I do not use the hook to pull. I wrap the strap around the crossmember or tow hook and put it in a slip know and back up til everything is taught and I readjust it if I need to, and then I pull out carefully in 4Lo.
I always tell the people I'm pulling out that I'm not responsible for any damages.
Old Jan 28, 2009
Thats why I have 2 straps now, I have one with the hooks and a recovery strap.
Old Jan 28, 2009
FullThrottle02's Avatar
Maybe one of these:
http://www.northerntool.com/webapp/w...70_22280_22280
Old Jan 28, 2009
Haha that might drag on the ground
jeffw920
Dec 10, 2012 12:26 PM
Metro55
Oct 18, 2009 10:49 PM
Metro55
Oct 17, 2009 05:42 PM
wvcat
Sep 5, 2008 01:29 PM
Ranger1
26
Dec 10, 2004 03:47 PM
