Torsion Bar SAG
Old Apr 15, 2009
Riceman's Avatar
Torsion Bar SAG
I got my Chevy shackles in. As you can see in my avatar it had RAKE and a lot of it. In the wheel wells the front was at 33 driver and 33.5 passenger with the rear at 37. I thought i would compensate a couple inches with a torsion bar crank... BUT my truck hates me. I wasn't expecting to get 3 inches out of it, just wanted to get it back closer to stockish stance. 4 turns and the driver side #1 bar on my 2004 FX4 is maxed. The passenger bolt sits below the cover. The B bars on my bros 03 have more adjustment than my driver side. 4 turns brought me to 33.75 and 34.25.
What are my options?
New bar(s)?
Torsion keys? The keys wouldn't be bad because i would just use them to have at least some adjustment on the driver side, but then the bar is just going to sag more quickly and i'll have to get a new one anyway.
Old Apr 15, 2009
Toreador4x4's Avatar
New torsion bars. #1s are about 170 for the set now
Old Apr 15, 2009
Riceman's Avatar
What would replacing just the driver side bar hurt?
Old Apr 15, 2009
they should be replaced as a pair, like shocks and brakes
Old Apr 15, 2009
Riceman's Avatar
Thats what i thought. I'll check with my dealer tomorrow to see how much I can get the bars for.
Old Apr 15, 2009
Riceman's Avatar
There is a 04 Level II in the boneyard at work. It been stripped of all body panels, engine, driveline and interior. I could get the bars out of it for next to nothing. I'll check to see it they are any better than mine. If i can get them for nothing i can put of buying new ones for a while.
Old Apr 15, 2009
No aftermarket lift keys please...
Get bars. James...take pics of that truck for me...everything that could be good, i may be interested in.
Old Apr 15, 2009
Riceman's Avatar
It was hit in the front and rolled. Now that i think of it the driver front was NAILED so the bar there is probably effed. I'll check it out anyway. I'll get some pics of whats left. You may be disappointed. Its the truck i got my hooks from.
Old Apr 15, 2009
RangOH's Avatar
Whats the part numbers for the #1 Bars? anybody know off hand? i could use some myself.
Old Apr 15, 2009
edgeman4.0's Avatar
i'm gonna hack in with a question...
01 edge 4x4's had #1 bars in them stock right?
Old Apr 15, 2009
Riceman's Avatar
There is a thread with the numbers in it. I ran across it a while ago. If you have the VIN for a #1 equipped truck, the dealer can get them.
Old Apr 15, 2009
Riceman's Avatar
SPR code on the Identification sticker on the door jamb. Will either say 1, B, or F. My bros 03 Edge 4x4 has B's
I was reading the thread about 08+ ride height and just realized my truck sat as low in front as theirs did... It so sagtastic!
Old Apr 15, 2009
edgeman4.0's Avatar
my SPR code is 1r32b. so does that mean i have 1 bars or b bars?lol
Old Apr 15, 2009
Riceman's Avatar
The Torsion bar code is first, so #1's but the leaf spring code is usually C or K, not sure about the r32b. My SPR is 1C. Let someone more knowledgeable chime in.
Old Apr 15, 2009
edgeman4.0's Avatar
alright, thanks man. need further explanation on SPR code, anyone?
Old Apr 15, 2009
Riceman's Avatar
I think i know the problem. You want the code circled in yellow, not the one circled in black.
Found this picture in an old thread which, judging by the tire size, the sticker belongs to a Level II?
427613111.jpg?t=1239853055
Old Apr 15, 2009
edgeman4.0's Avatar
ok, i think that makes better sense.. going from the yellow circled number my code says 1K. thats the #1bars right?
Old Apr 15, 2009
Riceman's Avatar
Yes
Old Apr 15, 2009
Tys 4x4 FTW's Avatar
i thought fx4's had the stronger torsion bars stock??
Old Apr 15, 2009
edgeman4.0's Avatar
i thought that was what that meant. thanks dude, last time i checked #1 bars at the stealership i get parts from were around $175-$180 ish about 6 months ago? i may be wrong. but good luck on fixing that rake, it'll look great when you're done with it.
Old Apr 15, 2009
All L2's got #1 bars. All the others....it depends on whats on the truck...cab config, bed, drivetrain, etc. I think all 4x4's got either B or 1 bars.
Old Apr 15, 2009
Straight where I got my numbers....
Post dated 4-3-08...
Originally Posted by rwenzing
You should be able to order #1 bars from a Ford dealer for about $65 each. They are cheaper online but I have to believe that shipping would eat up the difference. Be sure to take the part numbers with you because, at the dealer, replacement bars are looked up by VIN based on the original build.
#1 part numbers:
F67Z-5B326-FA Pass side
F67Z-5B326-FB Driver side
Old Apr 15, 2009
ah gotcha
well i love my #1 bars :D
Old Apr 15, 2009
98rangerxlt's Avatar
I kinda like the rake look my self but thats me.
Old Apr 16, 2009
Riceman's Avatar
Priced torsion bars at the dealer... $150. Not in the budget right now. Its livable for now.
As it sits right now. Front sits three inches lower than the rear. AMAZING the difference a .75 inch crank will do.
I'll throw this one in for before/after (pathetic) crank.
And for Shane... I present the ruins of an FX4. Everything off the truck has been used or scrapped accordingly.
